Citroen AX Engine Transplants
Results 1 to 10 of 10
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Default Citroen AX Engine Transplants
    Hi All,
    Just wondering if anyone knows what engines (that are available down here) would be suitable for a easy-ish transplant into an AX?
    My brief research has led me to believe that 1.) The AX has a TU series engine; and 2.) The 205 SI, 306s, 405s, etc. all have a XU series engine and are therefore unsuitable for a transplant.
    Is this correct?
    Cheers.
    PS Is the 1.4 GT"i" we have in AU what they labelled the "forte"?
    Last edited by aquinian; 11th May 2012 at 02:06 AM. Reason: Added another question
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Oct 2003
    canberra
    831
    a petrol Belingo motor is the easiest transplant
    1000+ Posts gezza's Avatar
    Bunbury
    2,191
    Yes that is correct you wont het the ux engine sin there at all.
    You will however get a c2 vtr or vts engine in....
    Berlingo same engine
    Bristol/England!
    1,486
    Any TU series engine from 950 cc to 1600cc, petrol or diesel will fit.
    Of course, the electrical stuff may be a bit different....
    XU series engines are very much bigger & heavier, and wil not even fit in the engine bay, let alone in the engine mountings!
    Bunbury
    2,191
    They actually will fit, I have seen it done, its the engine mounts that are the issue
    WA
    604
    Thanks for the answers.
    I am just toying with the idea of an AX GT with a bit more than the standard 85hp. I guess similar to a 205 Mi16.
    Gezza, was the XU mod you saw a 16V?
    Cheers.
    Oct 2003
    canberra
    831
    You must have a shoehorn and small hands!!!
    Bristol/England!
    1,486
    Quote Originally Posted by gezza View Post
    This I really would like to see!
    Bunbury
    2,191
    Nope it was a 1.9 many years ago think it was on axoc forum as well, if you just type it in on search engine there..
    Was around 12 years ago ish
    WA
    604
    I thought it might have been 8v...
    However, what would stop one sticking a 206 TU5 engine into an AX? Or how about whacking the 206 head on the AX 1.4 block?
    Just wondering...
