DS Invagination
Results 1 to 11 of 11
Thread: DS Invagination
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,126
    Default DS Invagination
    Greetings all
    well!! today was supposed to be all about me! Baking a birthday cake with Mum.. however the DecidedlySpecial had other ideas. I had drained the Hydraurincage from the can and filled up with new LHM.. took the car outside for a bath and on inspection discovered the rear right suspension boot torn! ugggghhhhh!!
    With a quick call to Mr Kennedy I was able to verify the correct replacement procedure and indeed what would be required for the manoeuvre that is "invagination".
    Removing the cylinder wasn't too difficult. There's a small 8mm nut/bracket that holds it all in place?!?.. undid that, removed sphere, undid pressure feed and cut off drain hose. the boot part I mean.. removed ball and cup retaining pin and withdrew the cylinder towards the front of the car.
    You can see previous repair had used a screw clamp.. but the linen cloth for the ligarex on the other end was intact. As advised by Richo I simply replaced everything in reverse to ensure I had the boot on properly... pushed it onto the rod inside out.. refit cloth tape and new ligarex and then turned right side out and woo hooo!! invagination a go go!!
    All cleaned, replaced with new (original) boot and ligarex straps, new pressure line seal.
    Wisdom tells me I should do the other one as well.. but alas no time today.. back to the grind tomorrow unfortunately. Still once you've done it, the second time around is easier.
    Richo, many thanks once again my friend.. it's always good to have someone you can rely on for advice, especially at short notice.
    Matthew
    PS If you're wondering I'm 38 this year but keep in mind that I started working backwards once I turned 40.
    The offending sheath.
    Cylinder removed.. feed pipe closed with one of Richo's delicious pieces of engineering.
    Inside out..
    linen wrap
    Invaginated
    Completed unit
    Reinstalled
    16,321
    It would probably pay to check the other side while your back there
    8,159
    Icon12
    Quote Originally Posted by mnm View Post
    Greetings all
    Matthew
    Nice work Matthew, and Happy Birthday, using your system I'm about to turn 18
    08 C5 X7 HDi very Noir
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    Bravo on tackling another job. With the right approach its an easy task. With the wrong approach all sorts of things can be damaged.
    Wisdom would also say how good is the "on high" bump stop? It stops the piston from forcing out on the boot.
    Citroen Car Club of New South Wales member.
    My Citroen ID21F can be seen here http://www.flickr.com/photos/frontdr...7605999522616/
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    Nicely done Matthew.
    A pleasure to be of remote assistance.
    You're the one who is able to understand and follow instructions, to the letter. Matthew, that's a rare, enviable quality.
    Thanks for sharing the images.
    Feb 2002
    Coolum Beach
    1,876
    "invagination".
    Sorry?
    DS Un jour, DS toujours !
    mnm
    mnm is offline
    Dec 2010
    3,126
    Quote Originally Posted by harrisson_citroen View Post
    Sorry?
    The infolding of one part within another.
    Ici.
    2,521
    I should take a shot of my boots, they are waiting for invagination tout sweet!
    So much to do so much time...
    Looks exactly like what has to be achieved thanks, did you have to file anything back or grease the cups?
    mnm
    mnm is offline
    Dec 2010
    3,126
    Hello
    I had replaced the balls and cups last year so they are good to go. They did need replacing though at the time.. the cups were badly scored.. giving that "click click" when the car rose after start up.
    You can follow that on another thread.. "DS rear cups".
    Matthew
    DS
    DS is offline
    641
    I'll add this set of my pics to this threads very useful pics.
    http://www.flickr.com/photos/frontdr...th/2599336277/
    Oct 2011
    Toowoomba
    647
    Default Invginneass thingy
    It looks funny, all clean like that!
