D Door needed urgently
    Kapunda
    449
    Default D Door needed urgently
    Last night a good friend of mine was hit in the rear RHS door ,the errant driver crossed the median strip destroved an oncoming car then hit my friend,It is a late D spec and she drives it every day.
    Any help would be greatly appreciated.
    Woody
    PS has any tried modifying an early door,I have a good one of those.
    Mar 2011
    Broom
    815
    the push button door mod is tough option. the door handle and the catch are quite different. Better to find a good RHS lift up door handle and work with that, there must be a few around.
    Good luck.
    9,670
    Insurance? You can now buy new skins, so if the frame is OK or can be fixed, any repairer should have a fair chance of fixing it.
    16,322
    If the existing door is rust free, it's going to be easier to bang the dent out than replace it. Good late 'D' panels are like hens teeth ( even ones that look nice are usually sh!t when you strip them back).
    shane L.
    Kapunda
    449
    Thanks for the advice.Sadly the frame is badly bent,top and bottom.Amazingly the window has survived albeit with abend of more than a centimetre.
    Woody
    9,670
    I could find you a door, but it will have rust and filler and it's a long way from Sydney. It's not easy finding clean used doors. There would be something better and nearer your home! The panel itself is nor very heavy once you remove the glass and regulator, which would make freight less costly.
    Check the classifieds as Bad Bertie in Sydney had some apparently good D Special doors on offer a few months ago. Last year, I recall some being on offer in Brisbane, but they may have been Pallas doors, the hassle being the many holes you will need to fill to use it on a Special.
    If it was rust free, you may be able to deskin it, straighten it and put it back together???
