eBay Lexias - buying tips
Results 1 to 14 of 14
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,876
    Default eBay Lexias - buying tips
    Are they all the same? There is an Australian seller flogging them off for $84!
    Are all Chinese lexia created equal?
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    I'm not about to put my hand up and say I'm any authority.
    I recently purchased one, it's on a single disc and works fine.
    Have read in other places where the latest (for sale on eBay) V47 on DIAGBOX is missing some stuff for the earlier cars. The factory is dropping off some of the earlier information.
    Mine is V45, pre diagbox.
    What's the worst case scenario? You lose $88?
    Well, not even that bad, you will have all the cables, then only need the disc to make it run.
    Hope this helps.
    11,302
    Who is the seller, or what is the link?
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    May 2002
    canberra...
    8,876
    May 2011
    Leeds, UK
    11
    Folks
    Has anyone any experience with this Lexia? Is it what it says it is?
    Thanks,
    Morgan.
    Feb 2011
    brisbane Au
    940
    Quote Originally Posted by Morgan View Post
    Folks
    Thanks,
    Morgan.
    China?? "caveat emptor"
    May 2002
    canberra...
    8,876
    Yeah well, for 88 bucks its worth a shot.
    This seller had 3 listings at 83, 87 and 88 dollars (odd). Went to buy it and noticed all but the 88 had been out up to $159 in line with other sellers! I jumped on the $88 listing which was gone shortly after.
    It turned up today. Appears new, although a but scuffed from being in a pile of them I guess. Software discs had grubby marks on them but seem to read ok....
    Have access to an XP laptop with no disc drive - so will have to try moving the disc contents to a USB drive and see if it works off that.
    Any tips for installing and using? It all looks Greek and complicated to me, but windows stuff usually does...
    Apr 2012
    Redcliffe
    78
    You can get fruity lexias at dan murphys for a lot less than $84!
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,518
    Or Greek retsina wines if you need to translate the Lexia.
    John
    May 2002
    canberra...
    8,876
    All good (well, beyond tearing my hair out at incomprehensible windows shite...), but I'm stumped at the activation code part.
    The keygen I was supplied does not create anything that gets me anything other than an error 11...
    Any tips? Or better yet, a known working code?
    Fellow Frogger! Balki's Avatar
    Sheffield/Tasmania
    633
    Default key code
    yep i had the same problem today, have a mate coming on monday to see if he can crack it for me
    May 2002
    canberra...
    8,876
    All the keygens I see mentioned on forums generate a code with a series of 4 characters separated by dashes, like a windows key. The keygen here has no spaces or dashes. It still doesn't work if put them in...
    Pretty sure the keygen is wrong...
    Mind you, it could be ****ing windows. Apparently old installs and virus crap can screw with it too. This is a borrowed laptop, so who knows what it's state is (beyond being bloody windows...). Might have to get a dedicated laptop with a clean install and no "security" stuff.
    May 2002
    canberra...
    8,876
    Got it. There was another file with the lexia 46 update. Updated it and the keygen then worked.
    Many faults... (found in 5 minutes -$195 worth of dealer time? Bloody thieves...).
    Transmission oil counter had not been reset...
    Fellow Frogger! CamM's Avatar
    Apr 2011
    Cherrybrook
    285
    Very tempted to buy a Lexia myself. So other than the initial setup, have you noticed any other problems/issues with the equipment you purchased from this eBay vendor?
    2005 Jaune Scott VTS 180 (built 28/1/05), K&N Typhoon Induction Kit, Bilstein B14 PSS Coilovers | Build Thread
    C4Owners.org Premier Club Member#19249
    Citroen Car Club of NSW Inc Member - 2013/14 Committee Member and Editor of "The Chevrons"
    Australian Racing Drivers' Club Member
    facebook.com/cccnsw
