C5 remote key got wet
Results 1 to 11 of 11
    Fellow Frogger! deesse's Avatar
    Dec 2010
    Melbourne Australia
    571
    Default C5 remote key got wet
    Hi folks my 2003 C5 key was left in my pocket when I went surfing. It worked first try after and I thought it would be OK. But no. I pulled it apart and dried all the bits but still doesn't work. Does anyone know how I go about getting a replacement/repair/second hand key and reprogramming it?
    cheers
    Tony
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    You will loose nothing so try this. Rinse thoroughly in fresh water and dry in the sun. Salt water is a conductor so there is probably residual salt on the board that is shorting something out. Hopefully no permanent damage has been done
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    10,187
    Try the rinse method first and even blow it dry with compressed air if possible. Since you've still got the key blade, you should be able to get a used circuit board and have it coded to the car. I'd expect it will require the security codes for the car, which a dealer would be able to obtain if you don't have them.
    Nov 2005
    Geraldton
    1,634
    In keeping with the above:
    Remove the battery. If the salt has operated as a conductor it may well have discharged by now.
    Flush and soak in demineralised/distilled water for a couple of hours. Blow dry with compressed air and dry. Try wrapping it in a tea towel and leaving on a mild heat source, eg the top of an espresso machine for a couple of hours.
    Replace the battery with a new one, reassemble and give a shot
    In the Shed(s):
    In the Past:
    11,294
    Quote Originally Posted by Greg C View Post
    That worked when I dropped my short wave radio into the salt water pool! Straight under the tap - I was immobilised otherwise with shock and bad language.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    ACT
    192
    For water affected equipment (phones, computers etc) I recently heard an ABC Radio electronics boffin suggest..
    - don't turn it on!
    - drain out what you can.
    - flush in demineralised water if salt-affected.
    - disassemble as much as practicable, place in a box and cover everything with (highly absorbent) rice.
    - replenish with fresh rice, as needed, after vacuuming soggy old rice away with a soft bristle attachment.
    - leave it as above for a full week, before your first attempt.
    He exampled a flood-affected I-Pad, with water literally pouring out of it, functioned perfectly after the above procedure.
    Fellow Frogger! ntr1972's Avatar
    Aug 2011
    Hobart, Australia
    315
    Go through the flushing process but don't put it on a mild heat source....stick it in a bowl of rice. The rice will draw out the moisture.
    10,187
    Place it in a sealed container/bag with a dessicant product like Damp-Rid would be another way to dry it out.
    Dec 2010
    Melbourne Australia
    571
    Default source of key circuit board for C5
    thanks everyone.
    I did dry it thoroughly and replace the battery, but I think the mistake I made was using it a couple of times and of course pushing the button to try it again and again. If it was wet when I did this it probably shorted out. So I think what I will need is a new/used circuit board to try to reprogram to suit my car. Despite living with cars for years with just a key I have got used to the convenience of pushing the button and I loved the window button to close or open the windows when not in the car. So I feel the loss.
    Anyway can anyone suggest a source of a circuit board, new or used?
    cheers
    Tony
    8,257
    Icon3
    Quote Originally Posted by deesse View Post
    thanks everyone.
    cheers
    Tony
    Check ebay UK, a quick search turned up this one
    http://www.ebay.co.uk/itm/CITROEN-XS...item3cc40483ff
    08 C5 X7 HDi very Noir
    Dec 2010
    Melbourne Australia
    571
    thanks Chris,
    I just bought a key on ebay for less than $20 including postage. Does anyone know what is involved in reprogramming it so it works in my key case? I noticed the local key cutter advertising this service. What numbers are needed etc.
    cheers Tony
