Does anyone know the formula for AC104 Gris Sable?
Results 1 to 18 of 18
    Jun 2004
    71
    Default Does anyone know the formula for AC104 Gris Sable?
    I need to get some paint mixed up for my Safari and AC104 Gris Sable (from 1963) is what I want.
    It's not on the system that paint shops in this country use, but the local paint shop only needs the exact tint formula to be able to produce it.
    I've tried googling to find it, but I imagine my inability to speak or understand French might be one of the reasons I can't find it.
    Can anyone help me to find the formula?
    (I know that there are squillions of other colours that are very close that I could choose from, but I want AC104, nothing else)
    1000+ Posts dino's Avatar
    Nov 2002
    4,758
    OK...
    I ve spoken to my supplier
    NOMIX tech department came back to me with this formula for AC 104 GRIS SABLE
    Only available in 2PAC 600 range...
    I asked for the formula to make 1 LITRE
    results are as follows (kinda like eurovision as she had an accent)
    633 467.6 gm
    631 640.5 gm
    601 45.1 gm
    603 10.4 gm
    I d suggest your supplier either speaks to "their supplier" or the technical department at NOMIX
    http://conceptpaints.com.au/contact_us/
    dino
    ps... do not for one second assume above formula is correct... I am only passing info onwards and upwards ... please make sure your supplier consults and confirms formula first... I d advise sample mix as well to confirm.
    Jun 2004
    71
    Default Wow, thanks
    Brilliant, thanks Dino. Will try to get a sample and see what it looks like before ordering 4 litres.
    16,753
    Hi Dino,
    have you ever tried that nomix paint. I googled it and the (very few) references I could find were very positive ..... Hmmm.... it's cheap too.
    http://www.sedl.com.au/catalog/index...h=81_88&page=3
    As for the colour code bit .... I'd be surprised if it's the exact colour. I found they only had the acrylic colour codes in the past with PPG, so what they did was lookup the colour chips for the colour. Then grab the urethane colour chips.... and compare them, it wasn't difficult to find a pretty much identical colour in the other paint system, then mix to the recipe of that colour (if that makes sense).
    Nov 2002
    4,758
    yeahhh I ve tried it... for small repairs... havent used it for bigger jobs... last big job I did was with chem-tech... and the black they mixed for me came up very nice...
    The nomix stuff seems good and we have supplied it to both backyarders and panels shops... ohhh I just remembered we used it on my brothers golf... painter thought it was pretty good... but admittedly he wasnt that great so.... in one ear and out the other regarding his advice...
    When I get to painting the D I m going to hunt for industry "best"... I dont know who that is at the moment... nowhere near that stage...
    dino
    10,192
    What about 'Rusty Green' Dino?
    Hi-Chem probably has it listed by the colour code and name too. The formulations is going to vary from one manufacturer to another though.
    Nov 2002
    4,758
    ohhh I think I ll just get them to mix me some " citroen green"... The "rusty" part of the formula I already have plenty of...
    dino
    Nov 2011
    Colchester, England
    75
    Quote Originally Posted by dino View Post
    OK...
    633 467.6 ml
    631 640.5 ml
    601 45.1 ml
    603 10.4 ml
    dino
    But surely this adds up to more than 1 litre? Unless you allow for 163 ml evaporation...
    Bernard
    Nov 2002
    4,758
    Quote Originally Posted by bernardrubingh View Post
    Bernard
    different paints have different weights... I ve made the correction to grams instead of mls....
    Above is a reasonably simple paint... some formulas require a minimum weight for the formula to be effective depending on the mixing ratio... most paints are mixed within 2 decimal points in terms of weight (up to 100 of a gram for small touch up containers)...
    dino
    Nov 2011
    Colchester, England
    75
    Hi Dino,
    Well, it goes to show my complete ignorance here... Learned something again!
    Bernard
    16,753
    Quote Originally Posted by wizardofaus View Post
    What a website !!
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    642
    For wheels I really wouldn't bother going to so much effort. There are lots of DS in Sydney with fresh painted wheels in nothing more than "light grey" and I've not seen anyone think it looks wrong. Its so close its seems silly to be so true to original. My ID19 wheels were powder coated many years ago and still look great.
    Citroen Car Club of New South Wales member.
    My Citroen ID21F can be seen here http://www.flickr.com/photos/frontdr...7605999522616/
    Jun 2004
    71
    Default Not for wheels!
    Gris Sable is not for the wheels, it's for the panels.
    That glasurit website gives me no information about the content of AC104, or am I missing something??
    Quote Originally Posted by DS View Post
    16,753
    I think I like that colour
    http://www.nuancierds.fr/AC%20104%20Gris%20Sable.htm
    I found a good way to find an exact colour to match, is to remove a door trim, behind these is several vinyl patches glued to the door. Peal these off and have a look at the paint beneath. This would be an ideal place to do some colour matching.
    My kids saw me looking through all the colours and want me to paint the car here this colour:
    "but it must sparkle like the car in the picture does ... " They must know what a half @rsed job I do of everything
    Ici.
    2,667
    that blue would have to be my favourite colour outside of Gris tholonet. noyce!
    Member wizardofaus's Avatar
    Loire Valley
    116
    Quote Originally Posted by bgbiteme View Post
    Nope - for some reason the Gris Sable doesn't appear to have a recipe - sorry - didn't check before I posted.
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,524
    When I wanted Jaune Mimosa paint for Daffy Duck, they got the formula from some mob in Adelaide, but it was only as a 2 pac formula.
    I wanted it as acrylic as it was for a bush car and I anticipated some touch up work. They then had to fudge the 2 pac formula to arrive at an acrylic formula. Not bad for a colour that was never originally in 2 pac. I think 2CVs were painted originally in acrylic (or more likely water colour).
    Unfortunately the magic formula has been lost, but I guess the process can be repeated if I need more.
    John
