Hello Folks,
Much has been said on removing the spring between the Xantia's brake pad and the rubber mushroom and replacing said spring with a similar length and diameter piece of conduit.
What I haven't seen is how on earth you remove the said spring. Reference to the Haynes Manual indicates that to remove the pedal you need to remove the dashboard (and I ain't doin' that).
Is the spring mechanism clipped the the pedal arm?
I don't want to go in there boots and all and wreck the mechanism...
Thanks in advance for any replies...
Andrew Matusiewicz
1999 Xantia SX 16 valve 5 speed
