DS winter treasures - Winterizing?
Results 1 to 7 of 7
    Fellow Frogger! Mort Subite's Avatar
    620
    Default DS winter treasures - Winterizing?
    Someone thought i should show some recent treasure...
    The other comment was "now you can have Comfort AND Reliability".....
    Charming.
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
    Los Angeles, CA USA
    1,955
    You lucky dog!
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    If they're both for the Safari I know which one I would prefer to fit!
    The repro heater taps are a good thing to be finally available.
    620
    Quote Originally Posted by richo View Post
    Unfortunately the easy fit item is for the DSpecial.
    ....yes the other one needs 16 bolts removed just to get to the cover plate.......
    but ive run out of gas too many times NOT to get it working and i drive in constant fear that I have forgotten to zero the trip meter...
    Jan 2006
    1,448
    When undertaking the rejuvenation of the Safari some years ago, I recall with no pleasure the replacement of those 16 5mm bolts.
    Over the entire job (the whole car), only two fasteners broke or failed. No prizes for guessing where one of them was!
    I removed the cover once more to remove the thread which had broken in the welded nut. A tense but successful recovery without damage to the original thread. Cow of a job.
    All the best for their smooth removal and replacement.
    Nov 2011
    Colchester, England
    75
    Default fuel gauge tank float
    Would you happen to know if this is a universal 12V float? The early D had either a Jaeger or Veglia fuel gauge with a 'matching' float. My Veglia float has given up the will to live. Your repro looks much better than those old bits of floating cork...
    On the same theme, the early D had either a Veglia or Jaeger water temp gauge, again each unit with a matching sender. Can be a pain, if they go wrong.
    Bernard
    620
    Quote Originally Posted by bernardrubingh View Post
    Bernard
    I dont know but it looks to be a standard plastic float.
    I would think most units use a plastic float now.
