Polishing stainless and alloy
Results 1 to 15 of 15
    16,748
    Default Polishing stainless and alloy
    Hi Guys,
    your CX's and D's have stainless bumpers and trims right ... check this article out:
    http://www.widman.biz/uploads/Polishing_Stainless.pdf
    It's a bloody ripper!
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,166
    Have just been doing the aluminium trim on the 11BL. Similar techniques and a Josco buff on the bench grinder to finish off. Tapered spindles are available for left and right rotation. Works a treat but hand polishing is necessary for the thin beads that go around the grille.
    I start with coarse grade wet and dry to remove oxidation and then progressively use finer grades till I end at 2000. Then either the buff or the Brasso to finish. POR also make a lacquer that is intended to protect metal that is natural in finish. I will investigate this later to avoid constant repolishing.
    Cheers Gerry
    Jun 2004
    71
    Default Incredible
    That is a sensational article, I would never have believed you could get this kind of result with such simple techniques and tools.
    Will be trying this on my ID21 Safari, thanks for sharing.
    8,257
    Icon3
    Hi Guys,
    That is pretty much the tack I have taken, with the exception of using the green compound rather than the red.
    Cheers Gerry
    Look into the POR lacquer carefully, I've seen it yellow badly over time (I'm speaking of POR Clear) gibgib used it on brake lines etc. on his 2CV restoration, perhaps they have an updated product now??
    08 C5 X7 HDi very Noir
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,517
    A terrific article backed up by before, during and after pictures. Looking at the gloves, the guy is definately not a wranker (with a silent "r"). Pity after all that work, he still ended up with a Convair.
    I bent and kinked the stainless strips down the rear windscreen of a CX and panel beated, filed and sanded it in a not dissimilar manner to that shown.
    John
    Member XantiaHead's Avatar
    Canberra, ACT
    88
    Icon14 Great article - brilliant results...
    Thanks for this link Shane.
    The stainless steel trim on my 1971 Alfa Spider will thank you too, in due course!
    Andrew Matusiewicz
    1999 Citroen Xantia SX 16 valve 5 speed
    1984 Alfasud Ti QV
    1971 Alfa Spider 1750 Veloce
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    He make it sound so easy but if you have time and patience the results will speak for themselves, it's just beautiful work this man did!
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    Member DSuper's Avatar
    Jul 2011
    Taranaki, New Zealand
    69
    Basically the process I went through (along with the panelbeater). (but he hammered onto a smooth brass block. I suspect a shaped piece of wood onto leather allows the 'memory' of the metal to help find the correct shape = better)
    I found going through the grits of sandpaper before polishing very important.
    I quickly got 85% of this result. For a similar result I suspect you'd have to take twice (or more) the time.
    Some of mine had already been professionally done, so doing a better job than I did would have out shone the professionals efforts!
    PS. If using a small bench grinder allow it to cool occasionally or you might blow it up (oops). Not using gloves allowed me to gauge the metal was not getting too hot. Polish away from edges - never catch an edge!!
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,448
    Quote Originally Posted by DSuper View Post
    These two points are most important, especially for anyone unfamiliar with polishing.
    11,301
    Wow! Great work. Thanks Shane.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Citroën CX Pallas 1980 (moved on to new custodian)
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,236
    I have a second set of front bumper bars for the DSpecial I was going to get polished up and replace the current slightly crumpled ones with... I notice someone has had the little metal nose piece for the front middle rubber, welded to the bumper!
    My question is, can this be removed without damaging the bumper and polished out.. ?
    Matthew
    Jan 2006
    1,448
    Quote Originally Posted by mnm View Post
    Matthew
    Pics please, to see the condition. Then report.
    Nov 2011
    Colchester, England
    75
    Default polishing alu
    Once you've done all the hard work like that chap in Bolivia (Shane's link), I've found that a small tube of Autosol works great to keep that shine. In particular older Safari models have a fair bit of alu decorating, which tends to tarnish/oxidise. I have tried clear coating, varnishing etc, but it tends to yellow over time. The creme is widely available and also works great on stainless. To get those rear lights looking as new, I removed the light units and carefully masked off the sides and placed both units in a blasting cabinet, using fine alu beads. This will give that mat alu finish around the lamps. The sides can be polished to a shine...
    Bernard
    Jul 2011
    Castlemaine VIC
    381
    Default aluminium trim
    Thanks Shane. Now I have some confidence in repairing the Safari roof aluminium trim. Why didn't I join Aussie Frogs years ago? It's brilliant what you "fellow froggers" come up with! Michael
    8,257
    Icon3
    Quote Originally Posted by bernardrubingh View Post
    Bernard
    ...agree, I really don't like the idea of clear coats, Autosol is quick and easy to use and leaves a protective film which slows the oxidisation process down. There is actually something quite nice about going around the car and keeping the alluminium and stainless looking good.
    Not a lot of alluminium to do on a D Special, boot lid lock handle and the hinges.
    Attached Thumbnails Attached Thumbnails Polishing stainless and alloy-boot-lock.jpg
