CX Rubber
Results 1 to 24 of 24
Thread: CX Rubber
    Fellow Frogger! laurie_lewis's Avatar
    Armidale, NSW
    234
    Default CX Rubber
    Hi all,
    Could anyone tell me if they have found suitable bailey channel and door rubber seal replacements around anywhere?
    Laurie
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    Quote Originally Posted by laurie_lewis View Post
    Hi all,
    Laurie
    Laurie ----have a look at Scott's Old Auto Rubber
    http://www.scottsoldautorubber.com.au/
    They may have suitable replacement sections. I doubt whether you will be able to get pinch weld for the door seals that is properly shaped for the corners of the door frames unless you try 'CX Basics'. A section will be available from Scott's but you will have to trim and bond the ends to fit the corners.
    Bailey channel should be no problem.
    Cheers Gerry
    Armidale, NSW
    234
    Hi Gerry,
    I am coming to grips with all these terms. So the pinchweld has to be cut at 45 deg angle and glued together, for the top corners. What kind of glue do you use?
    The rubber is all there but I was thinking that at almost 30 years of age new rubber and bailey channel would make the car quieter. Is this a correct assumption or not?
    I have contacted Scotts for a quote.
    Did you use any particular rubber for you CX?
    Laurie
    NORTH PERTH W.A.
    830
    All your noise is coming from those silly rear vision mirrors hate to hear them at 200mph on the jaguarXK220
    Fellow Frogger! Rob T's Avatar
    Oct 2002
    133
    Laurie,
    I used bailey channel that Clark rubber had in stock. They have a few sizes so you will need to take a sample in to match. The new rubber was not identical - but is a pretty close match. And it is certainley worth doing. I gave the offcut that I had left over to Kimmo. Maybe you could ask him if there is any identifying numbers on the rubber or maybe he might cut a sample off and post it too you.
    Clarks do have pinchweld (door seal rubber) and they will probably have a section that suits. The mitre in the top corner might be a bit tricky to cut and glue but it could be done. But I have never seen an after market section that is all that close to the Citroen original. I have used the Clark sections on the 306 and although it is far from identical it does do a good job of sealing. Note that Clarks retail prices aren't exactly cheap. When I was looking for a complete set of seal rubbers for the Fiat X 1/9 I searched the web and found a truck body builders supply company on the gold coast. They were half the price of Clarks and phone call with a credit card number soon had them on the way.
    I have also fitted new door seals on my CX. I got mine in a few transactions from eBay. Do check the price for seals from CX Basis. They won't be cheap but nor is buying small quanitities from Australian suppliers. And the original door seals will fit better.
    Robert Thorne
    Citroenless - for now...
    Armidale, NSW
    234
    All my noise is coming from the wife asking me to get the car back together so she can have her carport back. I would be happy with wind noise at this time.
    Laurie
    16,426
    I don't think mine leaks at all around the doors. Insulating the firewall and floors will make an immensely greater difference. As will fixing the windows so they don't close at an angle leaving gaps (if you ever figure that one out .................... You'll let me know right ).
    3,069
    Hi Gerry,
    Laurie
    I am still using original rubber strips and Bailey channel------It was all in good order. I have never tried to join the pinchweld sections by gluing. I think that Scott's would be able to recommend a glue!
    Pinchweld strip is just the mane given to the rubber cover that closes the weld seam around the doors. It is usually three metal flanges that are pinch together and spot welded in manufacture. Most modern cars have this type of join for the door frames.
    Cheers Gerry
    3,069
    Shane wind the windows closed on a CX and then loosen and re tighten the window regulator nuts while keeping upward hand pressure on the regulator and glass. This ensures that the glass is up tight in the channel against the rubbers and aligns the regulator properly!
    Cheers Gerry
    16,426
    Cheers Gerry
    I'll try ... but I don't think it'll work. It's a series II only problem as far as I'm aware. I've never had or seen and early car that does it. They angle the last 5mm before closure and whistle like crazy
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    The problem you will have is the rubber folding going around the corner at the bottom front of the door frame. All the sections I have tried from Clark Rubber do this and water leaks in. I don't know if the stuff available from CX Basis does but as it is only 11.31 Euro/m at the current exchange rates it is a bargain. You need 7m
    http://cx-basis.de/eshop/product_inf...oducts_id=4279
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Armidale, NSW
    234
    Hi Greg,
    That rubber looks a lot different from what was on my Turbo around the door opening. Is that rubber used on the actual door? Sorry I am a bit lost after looking at the picture on cx-basis website.
    Laurie
    Houston,Texas
    39
    I have been corresponding with a German CX owner and remembered that he ran an extra set of weather-stripping on his S1. I believe CX Basis provided him some of the parts. Here is part of our conversation on the subject:
    "Very important: the replacement of the old and hard window guides & rubber. Here Jochen Heusel can help you.
    Then: an additional and closed rubber-profile between door and body. I tested and now use the one I fixed to the body by using plastic clips from VW (holes been drilled in advance of the dipping); Jochen Heusel has a profile you can attach to the door.
    The effect: the feeling that the door and side-window had been moved out approx. 1 yd.
    Finally, especially for cruising at 80 and 90 mph (as we do here): the wind noise created by the cross-winds at the A-column.
    For testing I stuck in a piece of rubber and used sellotape of an appropriate width: incredible what difference that made! Like driving during the night without ANY crosswind at all. But the rain flowed over the side-windows so I copied what is done for modern cars: guiding the water up the windscreen."
    I am attaching pictures of the extra weather-stripping and other wind-noise mods.
    Attached Thumbnails Attached Thumbnails CX Rubber-p1010003.jpg   CX Rubber-p1010004.jpg   CX Rubber-p1010016.jpg   CX Rubber-p1010017.jpg
    Fellow Frogger! Stuart Dammery's Avatar
    453
    I remember pulling off some of the door rubber of a wreck Lozza, but I havent noticed it in my last few trips into my storage area, otherwise known as underneath my house, I'll have a look this weekend...but don't get your hopes too high
    1980 CX2400
    2000 Xantia Wagon
    Armidale, NSW
    234
    Default Pinchweld Sizes
    Hi Allen,
    Well I think you answered my question to Greg. It would appear that my car is fitted with enclosed pinchweld and that you can also get unenclosed pinchweld, which is what is on the CX Basis website.
    I have been looking at the link that Gerry provided and I have identified the size (or similar) that is fitted to my car. What is interesting is that there are larger enclosed seals as well as double seals so perhaps I need to look at it a bit more before deciding or getting some advice from the supplier. Larger seal might not necessarily mean better seal but it might, based on what I see in those photos there is a correlation between the amount of seal and noise.
    Shane & Archrival, when I was looking at the seals on CX-Basis I also saw the dust seals that go on the bottom of the doors for exported cars. I have them fitted to my C-Matic. They are not fitted to my turbo. Do either of you have them on your turbos and are they a worthwhile? Not really intending to take the turbo off the black stuff though once I get it back on the road (that will last 6 months).
    Laurie
    16,426
    No, don't fit them.... They rust the bottom off the door by retaining water against them indefinately. Though I must admit there is a friends '85 wagon here at the moment, and it has those rubber strips. They are not attached with self tappers straight into the door skin ( ) like the local cars. Do you want me to get a picture of the way they are attached It looks like plastic nuts on molded studs.
    My car is quieter than the C4 at speed since I've insulated it, exposed rain gutters and 40year old body design and all (the C4's tires can be really LOUD on some surfaces at speed). The door seals in your turbo shoudln't be to bad unless they were damaged when removed (it's younger than mine). The main noise comes from the front windows if they don't wind up right and the mirrors that whistle like crazy if you wind the front windows down.
    Armidale, NSW
    234
    No I don't think I will fit them, but was just asking. I can see how they are fitted on the c-matic and I suppose I am fortunate they have not rusted out.
    Yes I know about the wind noise so that was why I am going to fit new bailey channel to see if I can get that new car fit for a while.
    I have put down two layers of insulation on the floor and one on the roof of the car. Also put some dynamat extreme under the back parcel shelf to give it some weight.
    I have to take the windows out again to do some glass cleaning (working from back of car to front and only 18 months behind schedule) so while they where out I am thinking about putting some dynamat on the outer door skin.
    I want to make the car as quiet as I can without putting two tonnes of sound deadening and insulation in it.
    The door seals might be younger but have obviously had a rougher life. Damaged in places before I took them off.
    Laurie
    Bristol/England!
    1,486
    Now the weather is starting to get a little warmer, I will be starting work on my car... at long last.
    Hurrah!!
    Armidale, NSW
    234
    That's funny because I have to finish mine as the thunder clouds are building. Sunny outside though.
    Armidale, NSW
    234
    Gerry and other helpful souls,
    Since I am replacing my bailey channel and eventually the pinchweld ( love using those technical terms). I am looking at repairing/replacing the rubber strips that go along the top of the doors to prevent the water/dirt from falling down there.
    Don't know the technical term sorry, something else I have to learn.
    Now is there an easy way to update them or again is it Citroen specific rubber and not easy. I did damage one taking them off.
    Laurie
    3,069
    Laurie do you mean the external or the internal Glass seals?
    The internals often warp and distort with heat through the glass. They can be re straightened with heat ------- boiling water poured over them whilst laying in the bath ( the strips ---not yourself) When soft and supple just pull them straight again and cool with the cold tap.
    The external strip should be a commercially available strip. Have you asked Scotts about it? They have many more strips than those listed, but would need to see a cross section diagram showing the dimensions.
    Cheers Gerry
    Armidale, NSW
    234
    I was talking about the external ones. So if I can find the correct profile rubber they should slide into the metal holder?
    Great.
    I will send Scott's a sample.
    Laurie
    3,069
    Those metal clips were also used on Ford Escorts. So therefore there should be a repro rubber section available. The car that I restored for my daughter ( Escort Mk 2 ) was fitted with new glass seals but these were pre-cut to length for an Escort. It has a metal strip moulded into it to brace the section and to assist it to hold firmly into the clips. The original rubber on CXs is of very good quality and lasts very well. I know of several D boys who have used CX rubber on their Ds in place of the original that perishes very quickly.
    How come yours needs replacing?
    Cheers Gerry
    Armidale, NSW
    234
    Gerry,
    I damaged one in taking it out so was just thinking if I have to replace one why not 4 with new rubber. I may well be able to repair the one I damaged.
    My intention is to have this CX as my daily driver so I was going to try and make it as quiet as possible and that was in the back of my mind as well. Not that I think you will get a lot of wind noise from that area.
    Laurie
