2CV spring cyl Lube
Results 1 to 2 of 2
    Feb 2011
    230
    Default 2CV spring cyl Lube
    I put about 200 mls of veggie oil in both is this enough ?
    Feb 2003
    Sunny Melbourne
    79
    Two hundred mill is probably plenty.
    I usually fill each side up until it starts to leak out. The spring cans were never really intended to be leak-proof.
    Ultimately, the oil is only there to prevent the 'groaning' sound if the spring cans run dry.
    As long as you stick to using a vegtable oil you cant go too far wrong
    Ian
