CX Tyres
Results 1 to 25 of 25
Thread: CX Tyres
    Fellow Frogger! andrewj's Avatar
    Margate
    385
    Default CX Tyres
    I need some new tyres for the Red Rocket (CX).
    It it gets loaded to the gunnals with sea kayaks and camping gear at times, and is not shy about going down 4wd tracks.
    So what are the reccommendations?
    My experience so far has been:
    Kuhmo- side walls couldn't handle the weight at the front.
    XM1s- Ok but a bit of side wall flex + seemed to wear quick. Could have be a result of previous owner running at low pressure. Expensive now.
    TRX- Great, but a bit noisy. Not cost effective now.
    MXTE- Great wear, quite and comfortable but no longer available in the 185/80
    Driving - '90 XM, '85 CX IE Auto, 406 Coupe, 405 srdt wagon, '78 dyane, Resting (or Rusting): '73 Birotor '82 CX Presitige, '81 CX Break IE, GS X2, GS1015 Wagon, GS 1300 5sp Wagon, '76 GS 1220 Wagon, '75 GS Wagon, '58 2CV, '58 Vauxhall Velox
    16,416
    Standard 14" wheels ??
    You'll need to find what is available these days. I imagine there is little choice in tire sizes unless you go upto 16".
    I've found 215/55 16" rubber transforms the way a CX handles. The best combination I found with standard 6" wide 14" wheels, was 215/65 14" toyo's under it's nose, and 185/195 Michelins under it's tail. They are very "tail happy" and speed on loose gravel. Every other surface was fine.
    Margate
    385
    Yes, lack of tyre range at 14inches is frustating.
    I have managed to track down 175/80 MXTEs - given that 185's and 195's give tail happiness, I wonder if the 175's might be a bit better at cutting through loose gravel and water?
    10,786
    Quote Originally Posted by andrewj View Post
    I"ve got Bob Jane standards at the front and old full profile Michelin XZX at the back. Haven't tried it on gravel though..... Bit agricultural perhaps but it works for me.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Margate
    385
    New tyre time again!
    Have experimented with cheapy 195/75 at the front, but need to run very high pressures to avoid undue side wall flex when fully loaded.
    Has any one tried running a commercial tyre, say a 850kg rating rather than the original 650?
    Guess the other option is to go with the original MXVs or TRXes. With the dollar at 69p, they are very quickly moving from outlandishly expensive to just expensive. I do like the look of the larger metric rims...
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    I would go with 195/70 Michelin XM2. The XM1s now on the beast have been brilliant, lasted longer than any other tyre I have used on the CX. That and brilliant handling as well. The XM2s are supposed to be even better
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    16,416
    My experiance with TRX's (on fuegos ) is they are the worst tyres I've ever driven on .... ever .... I wouldn't pay money full stop for a TRX let alone the insane $$$ there worth
    Shane L..
    8,410
    What, something like this....
    http://www.tyreplus.com.au/?Products...leID=3&class=0
    Jo
    Margate
    385
    Yup - that's exactly what I am thinking...
    Other than a slightly lumpier ride, what's the catch?
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,231
    Shane L..
    I drove with TRX tyres on CXs in both the UK and Australia. I found them the best tyres for handling on the CX. The only other tyres I used on CXs were XVS (on the CX2400 metal rims before converting to TRX rims).
    Mind you, I have never driven a Fuego, so I don't know how bad they are.
    John
    JBN
    JBN is offline
    8,231
    I am amazed that the front tyres have undue tyre flex when fully loaded. The engine and transmission will weigh the same regardless of load. Most of the load is taken by the back tyres. If you put 6 bags of cement in the boot, ALL of the loaded weight is taken by the back tyres (and suspension). The beauty with a CX and other central system hydraulic Citroens is that since the rear brakes are pressured by the rear suspension spheres, the heavier the load, the greater the ratio of front/rear braking becomes biased to the rear.
    If you have a full length roof rack and load it to the hilt, there will be some more load on the front, but most is taken by the rear as the top of the windscreen is 1/3 of the way from the front of the car. Heavy front driver and passenger are marginal considerations. Surely there is a limit to the size of person that can bend enough to enter the CX at normal suspension ride height.
    I think that if you run very high tyre pressures, not only will ride comfort be diminished, but handling will also. All my CXs were in the days when the Michelin tyres developed for them were still in production. With all of my Citroens, the front tyres have always looked a bit more squashed than the rear because of the higher weight on the front suspension, but I figured that the engineers at Citroen probably noticed that as would their owner (Michelin) and the recommended tyres and pressures are pretty close to optimal. I found that the tyre/pressure table in the Haynes manual to be very good and rarely deviated from them, only occasionally dropping the rear pressures by a pound or two to improve ride. The rear of the CX dictates the comfort of the ride, both suspension pressures and tyre pressures.
    Having spun a CX once in the wet with good tyres (Michelin XVS), I would always be wary of "cheap" tyres. The difference in price between cheap tyres and good tyres is often less than the insurance excess (or indeed funeral expenses if its a bad accident).
    John
    8,410
    Not the best grip?? I wouldn't know, but at that price its probably worth finding out for yourself.
    Seems by your description your car is more of a mule than a stallion, so maybe the trade off will not be an issue.
    I reckon you'd get 100k km+ out of them too!!
    Not a bad bit of advice, although i'd point out that its not about the price/quality of the tyre, its about the tyre grip ballance and suspension tuning bias between the front and the back that really decides if you will spin.
    Put light truck tyres up front and michi PS3 up the rear and I will guarantee you wont be able to shift that ass without using the handbrake.
    Jo
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,065
    Jo
    Funny-----the CX handbrake works on the front wheels!!!!!!!!!! No hand brake turns with this beastie!
    Cheers Gerry
    8,410
    In reverse???
    Jo
    10,786
    John
    Which reminds me to ask your opinion about ride and handling aspects of running the specified size tyres, i.e. smaller ones at the back? Not done without an engineering reason I presume.
    Renault 4CV 1951
    Renault R8 1965
    JBN
    JBN is offline
    8,231
    I would think from an engineering point of view, it accepts the fact that the rear tyres are basically there to keep the bum off the ground to stop the exhaust from rubbing on the road. From a practical point of view, having all the tyres the same size allows for rotation of tyres from front to rear. Given that the front tyres take 80% of the punishment and mainly on the outer edges, it makes sense to move them to the rear once they start to squeal on corners. The rear tyres are happy with good tread in the centre, the fronts really need good tread on the edges (as well as the centres that wear slower).
    The short answer to you question is I haven't a clue why Citroen chose to have smaller (narrower) tyres on the rear of the CX.
    John
    I have no idea why the CX spun. I had been driving for 8 hours through the night. Stopped at Ballina for breaky. It had only been raining for about 1/2 an hour (roads may have been a bit greasy). I went through an S bend too fast. The arse let go. I was too slow to correct. I saw the railings of the bridge that we went over travelling backwards (and had a bad flashback to going over a bridge upside down in a Cortina many years earlier). The CX completed the spin (360 degrees) and ambled up the road as though nothing happened. I pulled over expecting to see a flat rear tyre, but all tyres looked OK. No excuse. Driver error.
    10,786
    John
    Wow. A moment to remember then...
    Many thanks re the tyres. I ought to look into it, as I can't fit a front tyre in the engine bay using the most sensible Bob Jane size (closest to the original dimensions I mean) but can fit the rear size in. Less weight and rolling resistance, and I guess some other aspects at the rear like less grip or less tendency to aquaplane given much less weight. Nothing to do with braking (you almost wonder why the CX had rear brakes at all). I presume that there was some theoretical benefit but in practice I have my doubts.
    Renault 4CV 1951
    Renault R8 1965
    Oct 2003
    1,304
    Citroen fitted smaller tyres on the back in the early days just like on the D. Later it was 185/14 all round and then 195/70/14. I would avoid those light truck tyres like the plague. Just put 195/70/14 XM2s on it and I am sure you will be happy. Sometimes I look at the front tyres and they look a bit squashed but if the gauge says they have 2.2 bar I don't worry. Normal for a CX with 70% of the weight on the front. Just checked my logbook, I fitted XM1s on 21/7/2009 at 273,952 miles. As of today I need new tyres and she is sitting on 319683. they have been rotated but that is 73,759km out of a set of tyres on a CX. I would not believe it except I have kept the records myself.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Oct 2003
    1,304
    Just ordered the XM2s, in stock in Australia and will be at Tyreplus Engadine next week. $140 per tyre. If they are as good as the XM1s I will be very pleased.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    I've just had the front exhaust sections replaced on 'Rusty' the CX and its lovely and quiet compared now. But now I can hear the noisy TRX's... WTF, its like old 4x4 tyre noise! I'm trying slightly higher pressure to see if that makes any difference 34 front and 29 back, but actually I think the noise level is exactly the same. I hope the tyre performance makes up for the hideous noise. Of course unless the noisy is bearings not tyres.
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    Oct 2003
    1,304
    I can't remember the TRXs I had on my Pug 504 being noisy, but that was a long time ago. Is it a bit noisier when you go round a gentle bend. In that case it could be bearings.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    8,410
    Bush way of eliminating tyre noise is to drive on grass.
    Jo
    Fellow Frogger! Rob T's Avatar
    Oct 2002
    133
    When I first fitted the Alfa mags to my car, I used the old tyres that were on the rims. Rears were a square blocky Conti that had quite a lot of feathering on the edges from their previous life. They were also a bit dry and hard. I guess they were about 5 years old. The 'instant' noise was dramatic. If I hadn't just fitted them, I would have sworn it was a wheel bearing. They did quiet down a little once they wore into the CX.
    Fitting new Michelins eliminated the noise (almost) completely. Now running Pilot Sport 3 in 205/55 ZR16. Really happy with them.
    My experience, FWIW, is that tyres seem to go off in about 3 years. Anything older seems to go dry and hard. Don't skimp on tyres. They are your only contact with Terra Firma.....
    Robert Thorne
    Citroenless - for now...
    Jan 2011
    749
    maybe an easy test is to swap to the DS wheels 185/15 michelins and run it round the block as an experiment?
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    NORTH PERTH W.A.
    830
    Quote Originally Posted by IE23 View Post
    good luck with your nuts do not think you will find your studs D and CX wheels are as alike as chalk and cheese
