GS oil
Results 1 to 7 of 7
Thread: GS oil
    NORTH PERTH W.A.
    853
    Default GS oil
    Wot's the best for a tired GS!
    Red Hill, Brisbane
    151
    Well for a good GS engine I use Penrite HPR15 but in a worn GS I have used Penrite HPR50.
    NORTH PERTH W.A.
    853
    Icon14 cheers
    I will try the sticky stuff and see how the rattles go
    16,691
    You mean gearbox ?? The motor should blow smoke on startup, it does by design.
    Oct 2011
    Toowoomba
    650
    Default One shot engines...
    Quote Originally Posted by ARCHRIVAL View Post
    Big end or main rattle? BEs are a problem because of the pressed together shaft...
    Mar 2005
    920
    Don't worry about the grade of oil.... just put a drip tray underneath and recycle what she loses. Topping up after smokey starts doesn't require much oil. remember the thing is a half way engine. Half way between a traditional 2 stroke motor bike with roller bearings and a real 4 stroker.....a double 2 CV !!!
    ( well almost ). I had a friend years ago with an Austin 1800..never needed an oil change ever.....the throughput from regular topping up had the same effect as regular oil changes. Being air cooled a G engine will tend to run hot especially after years of grime build up, despite the fan. I am sure someone will contribute about how extensively you can remove the pressed tin ducting with the engine in situ..either way a good degreasing especially around the oil cooler is worth the effort....might help remove some of the smelliness too.
    1,475
    I've never had a 1015 do that, it must be a 1220 thing.
    1972 SM
    1989 BX 16 Valve
