Xantia front break caliper
    Tadpole Nighty89's Avatar
    Oct 2011
    Poland
    20
    Default Xantia front break caliper
    Hi,
    Could someone tell me how to put together brake caliper? To be specific handbrake section. I've unfolded caliper to parts, cleaned it and put together by:
    - fully inserted piston into caliper,
    - screwed into piston that weird nut with spring badges and oring,
    - put that pastille on top of the nut, pushed it,
    - and slip the lever.
    And handbrake brakes almost on top of the handbrake lever, before it taken only 3 cloves.
    Thanks in advance.
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,044
    The handbrake self adjusts but needs normal braking to get this to happen. Some hard braking is sometimes required to get this to happen. So go for a drive and do some last minute stops at the traffic lights.
    Ken W
    Oct 2011
    Poland
    20
    Well, I did today 200km and still, nothing happens. The cord regulation is in the end.
    I belevie there is some trick to properly assembly the caliper. Maybe the piston should be put at the end?
    Feb 2011
    brisbane Au
    935
    Quote Originally Posted by Nighty89 View Post
    Hi, you're perfectly correct. The old trick was to pump up the brake pedal and hold it on. Then hold down the lock button of the handbrake lever and pull it up and down for at least five times. Then lock the handbrake on and release the foot brake. You might have to do this a couple of times but it usually works.
