DS queries
Results 1 to 3 of 3
Thread: DS queries
    Mar 2003
    369
    Icon5 DS queries
    Work on my 1970 DS21 creeps on slowly.
    I need to repaint the headlight plastic housing. Can someone suggest the type of paint to use (I'm thinking of a spraypack) and the correct color?
    My SEV Marchal distibutor has no vacuum advance. Is this normal for this model? I don't think I've ever had a car, French or otherwise, which did not have this feature.
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    8,244
    Icon12
    Quote Originally Posted by tresbon2 View Post
    Don
    Don,
    I think the accepted colour is Gris Rose, but like you I wanted to use a paint designed for plastic and for such a small area pressure pack. I'm very happy with the result, a nice satin finish that is hard to pick from the original unpainted plastic.
    No vacuum advance on your distributor is correct....
    08 C5 X7 HDi very Noir
    Fellow Frogger! Amopallas's Avatar
    140
    Don
    No vacuum advance on my DS 23 Pallas,with Ducellier distributor. There are many cars of the sixties and seventies,especially Italian cars such as the Alfa Romeo Giulia 105 cars,and the Fiat 124 cars that have no vacuum advance. On the Alfas,they have a Bosch distributor that has spring loaded centrifugal weights, under the points plate to provide advance. On the Fiats,they have a Magneti Marelli distributor that has the same set up as the Bosch units on Alfas. So a distributor without vacum advance is not uncommon
    1975 Citroen DS 23 Pallas
