DS selector shaft O ring replacement - how?
Results 1 to 12 of 12
    CitroŽn Tragic UFO's Avatar
    9,791
    Default DS selector shaft O ring replacement - how?
    For some years now the D's gearbox has been gently sharing its oil by seeping it out the worn O rings on each end of the selector shaft on the top front of the gearbox. I bought new O rings for it last year some time and attempted to fit them.
    As you can see in the attached diagram (circled in red) there is one each end (well it may not show it that clearly but there are) and the appropriate grooves in the gearbox housing and lid to accommodate them. The problem is the the left one (on this image) goes on easily. The right one of course has to get over the trapezoidal plate welded onto the end of the shaft - this piece then connects onto the rest of the mechanism that connects to the gear change lever.
    Trying to get O rings over that piece is impossible as they only stretch so far before ceasing being rings and commencing their life as a piece of rubber with two ends shaped in a rough circle.
    I bought some new O rings (6 this time just to be sure!) from a local diesel repair shop ( a real treasure trove of bits and pieces!) and might attempt the job again soon then drop the old oil out and treat the car to a fresh top up and Nulon G70.
    Can anyone offer some useful tips on getting the one required O ring over the plate? Note I did leave the old worn one on the shaft - just in case which was lucky.
    Thanks in advance
    Attached Thumbnails Attached Thumbnails DS selector shaft O ring replacement - how?-ds-4sp-gb-selector-shaft.jpg
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,406
    Cut it, install it, and glue it back together with o-ring glue.
    Or upgrade to a BVH.
    Only my second suggestion is facetious.
    Roger
    8,250
    Icon3
    Roger
    ...maybe try dropping it in boiling water before attempting to fit, of course use tongs to retrieve
    I also like Roger's second suggestion
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    Symar/ca/usa
    607
    If you are having to stretch it that much - it is not the right size to begin with.
    That ring is 3.6mm x 19.8mm. Got to your local 0-ring shop and source either an AS(BS) ring - in nitrile - size 210. The 210 will require just a bit of stretching, on the order of around 0.04" to fit over the shaft.
    Steve
    9,791
    Quote Originally Posted by Citroenfan View Post
    Steve
    Fitting it on the shaft is not the problem, it's getting it over the end plate.
    Los Angeles, CA USA
    1,955
    Did you try going over the shaft selector dong instead of the end? I bet you did.
    If that doesn't do it, Roger's plan A will work.
    Plan B is probably not an option.
    Greenblood's plan C sounds good, and I offer plan D now.
    Ship the car to Los Angeles, I will figure out how to fit the seal and then ship the car back to you.
    Mind you now, just because I offered does not mean I want you all to ship your cars. Just send the one for now.
    /does the Daffyduck dance wooohooo woooohoooo woooohooo
    Symar/ca/usa
    607
    Like Roger I have been with BVH for a long time. However if we are talking about the opposite end with the flector (shift linkage attaches), I just went out to the shop and put a 210 over one on a spare manual tranny in about 15 seconds with nary a problem. If the 0-rings are breaking it is a good sign they are either 1) cheap 0-rings or 2) been sitting on a shelf for a long time. Given the conversations I have had with Ricco about this my money is on cheap rings.
    Steve
    9,791
    Yeah thanks Daffy - sounds like a plan. Now if you could just organise a container and shipping but on a ship that does not go via NZ, I would be happy to put the car in there and fly over and meet it. I'll cover mine and Mrs UFO's airfares! If we can get it there about mid June you should have the car fixed in time for me to go the American Theatre Organ Society's convention that is in the LA area this July.
    Steve, I will work on the D this weekend and I suspect you may be right about the previous O rings. More than likely because I bought 6 spares the first one will be fine. Thanks for your test and response.
    12,278
    rogers suggestion would have been my method from the word go
    i own't stretch O rings, just cut and glue in a situation like this
    or
    buy a pug
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Symar/ca/usa
    607
    The trick is getting one over that end plate is to work it down as far as possible by hand. Then use a long thin flat bladed screwdriver, grease the shank, and using the opposite end of the end plate as a fulcrum point stretch the 0-ring and slide it down the screwdriver shank so that it pops over the end plate. Actually takes longer to write it all down than to actually do it
    Steve
    9,791
    Thanks all - I did the job yesterday and the new O rings that I bought a few weeks ago were far more flexible that the others I got from Holland. The ring stretched and slipped over the end plate without breaking. It was so successful I thought I would put a spare on the shaft just in case for the future.
    I took the opportunity to drain and refill the gearbox with 80 grade gearbox oil (2 litres required) and 250ml of Nulon G70.
    I also used about 1/2 a can of export degreaser to clean years of gunge of the outside of the box.
    No chance to drive it last night or today but will do so next weekend.
    Jun 2003
    Lauderdale, Tasmania
    2,888
    To avoid the risk of damaging the o-ring, drop the gearbox in liquid nitrogen. Remove, preferably wearing gloves, and slide the o-ring on. Easy..................
