Replace CX battery
Results 1 to 25 of 28
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    754
    Default Replace CX battery
    I never thought I'd write up how to install a battery in a car. But it is a CX!
    Found out that the LH headlight needs to be removed. In order to more easily do this the grill has to come off. Loosen the two bolts at the top, press the metal spring clips to allow the bottom of the grill to go back towards the radiator and then lift slightly and bring forward and out. Pic 1
    To remove the headlight there are three clips that sit behind the light that need to be prised off. The light then comes forward and out. The two black clips are at the sides, the white one is at the bottom of the light. Pic2
    The battery is retained by two metal clamps held in place with bolts attached to the carrier. Pic 3
    A 13mm socket and extension will allow removal through the headlight space.
    On removing the light I found that the glass was detached from the reflector. Someone had tried to silicone them together without much luck. Removed original sealant as well as the silicone before cleaning and then re-attaching. Pic 4
    Found the carrier was rusted so cleaned up and sprayed with a penetrating oil and sealer combination. Pic 5
    Next step is to apply primer before several coats of enamel.
    So what I thought was a ten minute job will run into several days.
    Have also repainted the trumpets on the horns. Pic 6
    Attached Thumbnails Attached Thumbnails Replace CX battery-dsc03886.jpg   Replace CX battery-dsc03887.jpg   Replace CX battery-dsc03888.jpg   Replace CX battery-dsc03891.jpg   Replace CX battery-dsc03889.jpg   Replace CX battery-dsc03892.jpg
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,158
    Isn't amazing how one simple task on a CX can lead to a whole weeks work!
    Interesting that your car has two removable clamps. Mine has only one. It is easy to undo the clamp without removing the headlight on my car, but having the light out gives a much easier space to lift the battery in and out, allowing that mine field of tortured twisted wiring to be cleared. Reminds me of no man's land between the WW1 trenches.
    Cheers Gerry
    10,116
    Depending on the battery, you can often get it in/out by removing just the globe and then lifting it out on it's end via one of the terminals and one of those battery handles. I guess if you can do this, the battery may be too small anyway. There is also a tendency for the wheel arch to rot out just behind the battery tray, so you've got to beware of laking batteries.
    Removing the headlamp is fairly easy. There was a note in the special tools thread I think about a tool made up to turn the three headlamp retainers easily. The one underneath on earlier cars is a pain to get at sometimes. Later cars have the top mount lights instead.
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Two points
    1. If the glass is coming off the reflector you can wash the inside of the glass. It is amazing how dirty it gets, so much so that I prized the other one off because it looked like the Prestige had a cataract in one eye.
    2. Luckily after 1982 one clip moved to the top of the light so it is easier to get the light out. Actually it is very easy compared to modern cars, when I had to do this at the auto electricians, he was amazed that it had to be done and how easy it was.
    If you are replacing the battery, I would suggest spending a few extra bucks and by an Optima fully sealed battery. I have one in the Prestige and it is brilliant. No leakage and very low self discharge.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    754
    With just about every car in the fleet requiring a new battery in the past six months or so the wife had an apoplexy when I went to buy yet 'another one!!!!'
    The one being replaced was an SCA branded one - lesser capacity than its replacement even though it is marked as the same model - a "59"
    With the car being an automatic it needs the battery. The 406HDi has a dead battery but at least I can roll start it if I need to move it!
    Current Cars
    1991 Mazda E2200
    1,475
    Is this the Familiale?
    I bought a new battery for it early last year - so I'm a little puzzled as to why it would need replacing. Did I leave you a warranty card?
    1972 SM
    1989 BX 16 Valve
    16,715
    I still have the original delkor in my CX .... that I must have fitted at least 8years ago. I'm still to have a delkor battery die
    I just tilt the batteries on there sides and lower them in... if you remove the globe they should fit easily enough.
    754
    It is the Familiale, no warranty paper but it must be just about at the twelve month mark anyway.
    The SCA Extra Heavy Duty (11 plate) is shown as CCA 420 and RC 90 - 12 mth warranty
    I've got a Century Hi-performance CCA 540 and RC 100 to replace it. - 24 mth warranty
    Current Cars
    1991 Mazda E2200
    castlemaine
    503
    Quote Originally Posted by rmac View Post
    You think this is bad try a SM. In the SM the correct sized battery has to be removed through a panel in the RHF wheel arch. To access the panel you have to remove the front wheel. To remove the front wheel you have to jack the car up. To jack the car up you have to start the engine. To start the engine you have to have a live battery. Go figure.
    roger
    CitroŽn Tragic UFO's Avatar
    9,787
    A friend in Wollongong was driving his SM to work one day a few years ago and the car suddenly stopped. The battery had dropped through the rusted battery tray and was only hanging on by the earth lead!
    11,225
    I made such a headlamp tool fairly easily! Ross has it easy relative to some (like mine) as one badly placed AC pipe also goes across - my last battery had to rotate in diagonally, starting upside down (after the old one had been leaking acid all over me on the way out).
    Nice blue trumpets!!!!! Hope they work.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    754
    The air con pipe/hose does go across but had enough flexibility to move it aside.
    Those trumpets are from 'Grace'. The pair you supplied are being painted at the moment. They didn't work but a combination of compressed air and thinners has given them a voice. The question now is "How long will they work?"
    Current Cars
    1991 Mazda E2200
    11,225
    Sounds as if the trumpets need more exercise! Perhaps a mid-day blare?
    Hope they behave.
    When I put the battery in the CX, the battery place's "fitter" refused to touch it, and reinforced his feelings when I undid the grill to allow the headlamp out......
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    I seem to be able to get my Bosch batteries in and out of the CX battlewagon by just removing the headlamp bulb. If they don't have a handle, I seem to remember having some sore fingernails for a while afterwards tho.
    Ken W
    9,787
    Hope they behave.
    What a namby pamby wuss he must be! He must go totally apoplectic when faced with a VW Beetle or Mini (original versions of both). I suppose a C6 or V6 C5 would also bring on a good dummy spit.
    11,225
    He was a grumpy old bugger to be sure. Perhaps it was me starting with a 10 mm spanner on the side of the car opposite the battery? Taking in the Renault R8 later that year did get a better reception.
    Wimps and wusses. You are quite right.
    754
    While waiting for the paint to dry in the battery area I took time to put the old battery on extended charge. Then when I went to town took it to the workshop and asked them to check it out.
    Despite me charging the battery overnight and having the green light on the charger (indicating fully charged) the test revealed 'Replace battery'
    The workshop put it on a quick boost. After which the test said 'Good Battery'
    The CCA read at 387 (battery described as CCA420) So I left them with the new battery and will go back to the car to check for other possible culprits.
    The final coat of paint will be dry tomorrow morning so will refit battery and see what happens!
    Be interesting to see if it holds the charge overnight!
    Current Cars
    1991 Mazda E2200
    11,225
    And? How did you go?
    754
    Fitted battery. Replaced headlight and one retaining clip (couldn't get the other two on) put grill back and started car. Easy!
    Drove across to my neighbours to do a small job then home again. Some jobs to do on the block so used the CX. Seemed fine.
    Left it overnight to see what happened. This morning she started easily. Drove to town the long way to attend to some business. Once in town went to workshop where they tested the battery in situ. Reading was good.
    Will now wait to see what happens over the next week or so.
    Did go back and managed to fit the other side clip on the light. Can't distort my hands enough to get the bottom one on though.
    Current Cars
    1991 Mazda E2200
    11,225
    I know what you mean - I'll try and remember to photograph for you the tool I made for that purpose. Basically it is a slotted 3/8 drive long socket with a short extension of the type with some movement.
    I've had that sort of battery nonsense myself. Use vehicle more, problem departs. Something about modern batteries perhaps?
    11,225
    Here you go Ross. My 9/16" socket slotted for the CX headlamp clips, with a 3/8" drive extension of the bendy joint variety. Works like a dream.
    Attached Thumbnails Attached Thumbnails Replace CX battery-cx-headlamp-clip-tool-1-sml.jpg   Replace CX battery-cx-headlamp-clip-tool-2-sml.jpg   Replace CX battery-cx-headlamp-clip-tool-3-sml.jpg
    754
    Thanks for the pics John. I'll dig out one of my old sockets and make one. I've been looking at buying a flexible extension to use in addition to the knuckle joint. I seem to come across nuts in difficult locations far too often.
    Current Cars
    1991 Mazda E2200
    11,225
    Pleasure Ross. I've had a fully flexible extension for years and have never found it to be much use! However, the universal joints and these straight extensions with curved male ends are really good.
    Of course the only reason I had a 9/16" socket was that it came with a mixed metric/Imperial set I bought cheaply. I've never owned a non-French car with those odd spanner sizes.
    I've had to resort to Scotch, the Jamieson having run out temporarily!
    9,787
    Ahem, I think you're on a completely wrong website if that's what you wish to discuss!!
    10,116
    ... straight extensions with curved male ends ...
    I presume you mean a 'wobble' bar. Allows the socket to pivot on the end unless you push it firmly home. The same idea is used on ball drivers, which are hex keys with a slight ball on the end. Sometimes, you really do need them.
