XU9JAZ (DKZ) igniotion timing/advance
Results 1 to 8 of 8
    Tadpole Nighty89's Avatar
    Oct 2011
    Poland
    20
    Default XU9JAZ (DKZ) igniotion timing/advance
    Hi,
    Which sensors ECU uses to advance ignition timing? I run mostly on LPG (BRC Blos) and i'm afraid, that ignition is not advancing when i push pedal to the metal.
    And another question, this engine has almost standard ignition distributor, but without vacuum advancer, but there is some regulation like in standard distributor, but when I turn distributor clockwise/counter clockwise - nothing happens. Is there a way to advance timing (for LPG)?
    Engine: XU9JAZ (DKZ) taken from '91 ZX Volcane and fitted into Citroen BX, replacing the same engine. ECU, airflow meter etc. stayed the same.
    ECU: Bosch Motronic MP1.3.
    Thanks in advance!
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    558
    The timing is contolled by the ECU , it recives a crank angle signal from the sensor mounted on the top of the bell housing.
    If you wish to change your timing you could slot the mounting holes and move the sensor towards the rear of the car.This will not change the shape of the advance curve but will move the timing accross the whole rev range.
    Or you could replace the ECU with a programable unit or fit an interceptor type ECU.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Oct 2011
    Poland
    20
    Thanks for reply.
    Does that requires dismantling gearbox, or drilling in it?
    Coffs Harbour, NSW, Australia
    625
    Moving the sensor will give you more advance across the entire range.
    LPG requires substantial early advance, but less at the top.
    More total advance will give better low speed response & performance but prevent the motor
    from revving out & even cause damage. It can also cause unacceptable problems when the motor
    is switched back to petrol.
    A dual curve system is the ideal solution so you can switch between the two, or if on gas only,
    a system with a LPG curve.
    Cheers, Richard
    7,528
    Try fitting a chip from an Mi16 (must be 3 row 1.3). They have less total timing and more down low. Should be better with LPG. Also, I have Mi16 chips which have less again up top and even more down low. They're $45 + postage. I also have standard chips you can try for free.
    Oct 2011
    Poland
    20
    By chips you mean ECU?
    I use this car for long distance travelling, so i drive only on LPG i even start cold engine on it. Yes, i know it's not recomended, but i know what I'm doing.
    Thanks for offer, but as You see I'm from Poland, so it's not an option. We have a lot of Mi16 on our used market. :-)
    Why am i troubling with all this? On standard road, driving under 3000RPM (city etc) and LPG my car drive like an 1.6, on petrol it has like 40 more HP, but accelerating with pedal to the metal from 0-100km/h on LPG is almost the same as on petrol. LPG installation is fine.
    EDIT:
    Is it possible to mount standard distributor with vacuum ignition advancer e.g. from XU5? What besides distributor would I need?
    7,528
    By chip I mean the actual ECU chip itself. This contains the fuel and ignition mapping. Open the case up and change it, like this:
    http://www.taylor-eng.com/ecu/case_opening2.html
    The picture is of a 2 row case, 3 row is very similar.
    What does it matter if you're in Poland?
    I had a Nissan Patrol which I drove on LPG only for 300 000+Km. The metallurgy in XU engines is equally as good. ie hardened valve seats and bronze guides.
    Oct 2011
    Poland
    20
    Okay, i will go into deprecating the ignition system, by replacing ignition distributor with one that has vacum ignition advancer/retarder. At least for now, to see if there's a difference.
    I have spare one from a TU3 engine - it fits just fine in XU9, but will it work correctly?
    PeterT: i've done what You said, and replaced the chip with the 16V one (from BX), and there's not much of a difference. I'm afraid i have wrong/damaged ECU.
