Remote Xantia
Thread: Remote Xantia
    Fellow Frogger! IE23's Avatar
    Jan 2011
    749
    Default Remote Xantia
    My keyless door remote has stopped working. I replaced the battery but still no life. Anyone experienced this and what are the possible fixes?
    Adrian
    _________________
    Current;
    Xantia V6 Exclusive Auto 2000
    Past;
    CX25 GTI Turbo series 1 1985
    DS23 IE Pallas 5sp 1974
    CX25ie Pallas Auto 1984 Parts
    2CV 1988
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    What model Xantia. Our VSX has had an aftermarket unit fitted as it is cheaper than the genuine part (surprise surprise). Also it works at much greater range than the standard unit did so it is better overall. Thats a 1994 VSX
    Our SX is still working with the original plip, well half working as it will no longer lock the car. I am sure the problem is the switch in the remote unit has become disconnected from the circuit board. I have already been there with my soldering iron and it was more good luck than good management that fixed the unlock function as the switches are surface mount components and very small. The SX is a 2000 model.
    If the whole thing has stopped working it is probably the main unit so a new aftermarket system would be the best option.
    I assume you have checked the relevant fuse
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    Jan 2011
    749
    Thanks Greg I'll check the fuse. 2000 model
    Adrian
    _________________
    Current;
    Past;
    2CV 1988
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,474
    Quote Originally Posted by IE23 View Post
    You may be interested in "Flick the Plip" thread that I have just posted.
    John
    Melbourne, Victoria.
    1,390
    Hi there IE23,
    if you are any kind of electronic service wizzard, and can use a very fine, small soldering iron you should be able to fix it.
    I found that mine had two dry joints, these are very common.
    If you are not confident you could post it to me, I live in Melbourne, and I'll happily repair any bad or "dry" solder joints for you, for a bottle of Limoncello or similar.
    Cheers...George 1/8th.
    Well, you see, I like Limoncello.
