2002 v6 citroen c5 - sudden engine failure
Results 1 to 25 of 31
    Jan 2012
    Perth, WA
    8
    Default 2002 v6 citroen c5 - sudden engine failure
    Hi All,
    I had the misfortune of the engine suddenly cutting out on Monday afternoon.
    It was getting low on fuel - but the computer said another 65k left.
    5 litres added made no difference and the RAC serviceman injected 50ml of petrol into the intake manifiold.
    Car was taken home on a RAC flatbed truck.
    The breakdown serviceman found no input to the ignition coils - suspecting crankshaft or camshaft sensor failure.
    Haven't had a chance to do any systematic investigation and the Haynes manual doesn't include the V6 engine anyway.
    Strangely, there is no voltage present on either side of the fuel pump fuse with the ignition on.
    Is that normal, or is there a fuel pump relay before the fuse that could have failed?
    Any advice appreciated on the likely culprit.
    Where exactly are the crankshaft and camshaft position sensors located, I presume the crankshaft sensor to be picking up the flywheel.
    CitroŽn Tragic UFO's Avatar
    9,786
    Is there a safety cutout switch in the engine bay somewhere that may have popped to the off position? If there is it may be a rubber block looking thing about 3cm square with a round top and indent. Could be on the driver's side of the engine bay back near the firewall (and I am only guessing as I do not have the same C5 as you).
    If you find it, push it and see if it clicks and then try the engine.
    Sep 2003
    North Parramatta
    4,010
    For reference, the button UFO is referring to is the red one near the passenger side strut top in this pic:
    How are you checking voltage either side of the fuse?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    12,278
    this happened to my mother last year in her 206
    it went to a service centre and they disconnected the battery to reset everything after checking various sensors and everything reset and it hasn't played up since
    that was around 6 months ago
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Apr 2005
    Sydney Australia
    49
    So does this mean there is a cutout system on C5 V6 Series 1 models (and perhaps on other models) that can kill the engine, without warning, based on a set of engine sensor readings? Sounds much like a windows Stop Error (aka Blue Screen of Death). How much redundancy and duplication is built into that particular system?
    Jan 2012
    Perth, WA
    8
    Thanks UFO and SLC206 for your advice.
    However mine doesn't appear to hava a cutout near the firewall on either side - photos attached. Mine is a Jan 2002 build date.
    I also checked another vehicle on a used car lot last night - no voltage on either side of the fuel pump fuse with ignition on - so that can't be the problem.
    Attached Thumbnails Attached Thumbnails 2002 v6 citroen c5 - sudden engine failure-dscn1025.jpg   2002 v6 citroen c5 - sudden engine failure-dscn1026.jpg
    10,102
    The car has a fault log and will record problems. Did the patrolman read the fault log? Most of them can, although they may have trouble interpreting some of the specifics. If there is no fuel pressure, it will have a low pressure fault and if there is an ignition fault, it would have one or more ignition fault codes.
    It should splutter before it stops if you are simply out of fuel. Was it a dead cut off or were there some symptoms beforehand? Have you run the fuel down that low before and were you on the flat or an incline? The tank sender may not be entirely accurate and if there is very little fuel in the tank and the tank is inclined, the pickup (on the right) can be left dry.
    Does the car lock and unlock normally? Have you tried the second remote / key?
    I assume it cranks easily. Does anything else electrical not work? Have you checked all the fuses?
    Jan 2012
    Perth, WA
    8
    Thanks David,
    No the RAC breakdown man didn't use any device to read fault codes - and had a little difficulty attaching a tell tale light to the coil leads to check for ignition pulses.
    Will check that again tonight - should get some indication on a small globe or multimeter.
    The vehicle stopped while travelling along a level road - and yes, it didn't seem like it ran out of fuel - done that before - you usually get some stuttering before it stops completely.
    Might put another 10 litres of PULP in tonight to make sure.
    Jan 2012
    Perth, WA
    8
    Hi David,
    I lost the second key some time ago - I thought I would find it during a big clean-up - but no - one of the things to do is purchase another before I lose this one.
    Might try a new battery in the remote key.
    Doors unlock and lock OK, but I did get an "immobiliser fault" at one stage on the info screen. It doesn't show now though.
    San Diego, California, USA
    3,543
    Hi Savro-
    I don't know the C5 from Adam (we haven't gotten a new Citroen here since 1973), but I do know that a low or flat battery can produce some really weird faults, even if the alternator is up to spec. A suggestion I have is charge and check the state of the battery. You should see about 12.2-12.5v at rest. If the battery is older, say 5 years or so +, you're due for a new one.
    Bill
    Jan 2012
    Perth, WA
    8
    The battery could not be the problem - a new one was installed 6 months ago.
    It would not cause the engine just cutting out while driving.
    11,220
    Quote Originally Posted by Savro View Post
    A battery could die actually at 6 months or have some funny internal fault, or the connections to the battery could be dubious. Not likely I agree, but batteries sometimes die prematurely - hence the typical warranty arrangements.
    Good luck with the frustrations! I agree that there should be some faults logged, waiting for translation.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Jan 2012
    Perth, WA
    8
    Thanks for the advice so far guys.
    Can anyone advise where the flywheel angle sensor is located?
    I found the camshaft sensor - at the RHS of the front bank camshaft gallery. I presume the sensor becomes coated with engine oil in normal operation.
    3,543
    Yah, you're right, nothing really to agree with re: possible problems, just something to check. We occasionally got a car in due to be converted to a limo and the battery was the culprit for all sorts of bizarre problems. I also saw this every great once in a while on streetrod builds.
    Something else to check if your sensors turn out OK: the fuel pump itself. If it's an internal style the fuel is the lubricant. Running it low on fuel can cause the pump to seize. Chances are though this would have blown the fuse due to overloading.
    Jan 2012
    Perth, WA
    8
    Still getting an occasional "Immobiliser Fault" showing on the information panel.
    The one and only remote key sometimes gives trouble locking and unlocking the doors - could this be part of the problem?
    The owners handbook doesn't show any fuse protecting the immobiliser circuit that i could check.
    I wouldn't have thought that an immobilier fault would have occurred while driving and stop the engine - a potentially dangerous occurrence.
    Anyone able to advise the location of the crankshaft or flywheel sensor as pwer my earlier post?
    Regards
    NSW
    4,918
    Savro, I think its time to take it to a French mechanic in Perth.
    12,278
    have you had the faults read yet ??
    what faults came up ??
    after reading the codes has it been reset ??
    is the problem still there after doing all this ??
    crank sensor will be either on the bell housing or at the back of one of the heads on the camshaft. you will need to remove the engine cover
    do the above first and let me know how it goes
    1 x 2018 3008
    11,220
    Quote Originally Posted by danielsydney View Post
    And there are a couple worth considering! Possibly more.
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    467
    I had the exact same problem with my C4
    no fuel pump
    coil faults
    etc etc
    motor would turn over but not start
    Turns out there is a known problem with the fuse box PC board same unit in the C5 C4 and C6.
    I had gosford eurocars swap out the box from a used car and hey presto movo.
    My vehicle is under extended warranty so the $1500.00 replacement cost didnt hurt.
    Good luck
    Jan 2012
    Perth, WA
    8
    Thanks Don for your suggestion.
    It may well be that it is the immobiliser that is the problem, but if so it only affects ignition - fuel supply and starter operation unaffected. I thought immobilisers were required to disable at least 2 functions.
    A little concern that an immobiliser fault could occur while you were driving - particularly if you were overtaking.
    Where exactly was the fuse box circuit board located - there are two fuseboxes - one in the engine bay and another in the glovebox.
    Regards
    Sep 2003
    North Parramatta
    4,010
    The immobiliser has no effect on the starter function.
    Simon
    10,102
    The immobiliser will lock the engine ECU and therefore disable quite a lot even though it may still crank OK.
    NSW
    4,918
    I think its time for a dealer to look at this C5?
    12,278
    Regards
    Have you gone through the codes yet ??
    i mentioned this earlier and asked for a reply, trying to help you through but..............
    start with the simple things first
    1 x 2018 3008
    Sydney, NSW
    427
    Default C5 v6
    Hi there Sarvo,
    I'm not sure if you are the lady or gent who posted the C5 v6 hassles recently, and won't get to check, but what is taking place here is a whole lot of guessing, with the ver best of intentions.
    My advice to the last c5 v6 saga was to not muck around with el cheapo mechanics of any kind.
    Take STRAIGHT to your Citroen dealer and get it correctly diagnosed and fixed.
    This car will cost, and I guess if you intend keeping, think of it as a bit of an exotic, or you will tear your hair out big time.
    Repeat, Daniels advice and my advice, TAKE THIS CAR TO A DEALER. Misdiagnosis may potentially cost you even more.
    Chris Mortimer
