C5 2010 hdi 2 ltr
Results 1 to 9 of 9
    RYE Vic
    194
    Default C5 2010 hdi 2 ltr
    What size socket do I need to remove the oil filter cap, local diesel mechanic thinks its 27mm 6 point and not 12 point this mechanic only works on trucks, any help would be appreciated thanks in advance.
    Tony
    Sep 2003
    North Parramatta
    4,011
    Quote Originally Posted by scarfjoin View Post
    Tony
    The filter cap is indeed a 6 point 27mm size. You can use a 12 point socket on it, of course.
    It shouldn't be done up too tight. From memory, it's around 25Nm, but it is written on the cap.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    Icon4 Get a six point socket
    A 12 point will run the risk of ripping the corners off it. I gave up on doing mine the first time because I only had a 12 point. Mechanic says they are fine with 6 point so I have made the big investment for next time.
    Ken W
    RYE Vic
    194
    Thanks Ken W, thats what the diesel mechanic said about the 12point socket, I have been quoted $6.90 exploit brand up to $119.00 for some unknown brand 6point the only info I got was that is a shallow 27 mm, local auto parts dont carry 6 point sockets, any other advice as to who sells 6 point 27mm would be appreciated.
    Tony
    CitroŽn Tragic UFO's Avatar
    9,787
    Gee I remember doing one of these on a Series 2 C5 a few years ago and I think we carefully used a 27mm open ended spanner. The cover is not "apprentice tight" so should come off fairly easily.
    1000+ Posts stuartb's Avatar
    Apr 2002
    somewhere over the rainbow
    1,445
    airtools are 6 point
    Apr 2002
    1,445
    Quote Originally Posted by SLC206 View Post
    its plastic so absolutely no no way 12 point
    Sep 2003
    North Parramatta
    4,011
    My plastic oil filter cap has survived eight removals and eight refittings with a 12 point 27mm socket and it's still the same as the day I first bought the car.
    I find it weird that people on this forum actively advocate welding up dodgy tools to undo sump plugs but then get all prissy about a very low torque plastic filter housing
    Still, if one is going to be a butcher with tools, it won't matter which tool they use!
    Simon
    North Brisbane
    2,047
    The one I tried and was not game to go on with using a 12 point socket was the diesel fuel filter housing. It was too tight for a 12 point socket. There is a ridge in the fuel filter cap that stops you getting the full purchase on the hex outline.
    I have now bought a 6 point half inch drive impact socket from trade tools for less than $20 that I am sure will do the job OK. I might even grind some slots in it so that the ridge is accommodated OK.
    Ken W
