XM Repairs in Northern Melbourne?
Results 1 to 7 of 7
    Dec 2011
    Mill Park
    1
    Default XM Repairs in Northern Melbourne?
    Hi All,
    I just moved to Melbourne and during the move I believe my speedo cable broke. I'm guessing it was the speedo cable as that was what needed replacing last time the speedo went dead - that was about 18 months ago. Does anyone know a Citroen specialist/mechanic in the northern suburbs of Melbourne? It's for a '91 XM V6.
    Luke
    Member ajm212's Avatar
    May 2011
    91
    It's not as north as you might wish, but I take my XM to Citro Motors in Fitzroy. Mel services a number of XMs and his wife used to drive one. To the best of my knowledge, the other Citroen mechanics on the northern side of the city are also pretty much in inner/middle suburbs.
    I think Citro motors closes until the end of January part way through this week, so if you decide you want them to do the work, you should probably talk to Mel pretty quickly.
    Andrew
    CITRO MOTORS
    15 -17 Smith St Fitzroy 3065
    (03) 9419 4537
    CitroŽn Tragic UFO's Avatar
    9,787
    In the interim if you have a GPS use this as your speedo.
    Fellow Frogger! sparkey's Avatar
    Apr 2005
    381
    Quote Originally Posted by xylophonica View Post
    Hi All,
    Luke
    A bit closer to home for you is Cars of France (Darebin Tyre and Service Centre) 170 Grange Rd, Fairfield 9499 7522. Nick is the specialist there. I attempted to book in before xmas last year & they were flat strap.
    '73 & '74 GS Break
    '00 Xantia Break
    '78 504 GL - gone to good home
    '69 ID19B - if wasn't for mortgage would still have, '74 DS23 Pallas
    '74 Renault TS , '69 Renault TS - last seen forlorn at Taminda wreckers
    16,705
    There isn't a cable is there ?? It'll probably be dry solder joints in the dash. Try giving it a slap or two on top and see if the speedo starts working again. I think the diesel model somehow uses a flywheel sensor for it's speedo (yeah that one has me buggered, it must know what gear the car is in to calculate the speed).
    I'll see if I can find the photos of the XM dash and upload them. They would have been all lost in the crash.
    Fellow Frogger! denxm's Avatar
    uki aust
    451
    Default need for speed
    you should check if it is the cable by taking out the instrument panel ,go for a short drive and see -feel if the cable is turning, easy to do
    the plastic connector on end of cable can come loose from speedo also
    if it is the cable it is not too hard to replace yourself, no better or worse than most if you cannot
    get a garage this time of year to do it
    Fellow Frogger! caparobertsan's Avatar
    May 2011
    SOUTH MORANG
    793
    Default Service centre
    So Where did you end up taking your car? Please let me know as I have to take mine too.
