pyrometer
Results 1 to 9 of 9
Thread: pyrometer
    Dec 2010
    258
    Default pyrometer
    Any suggestions about the best source(s) of a pyrometer suitable for automotive use?
    My immediate use is to detect temperatures around the cooling system.
    8,378
    Jaycar sell an infra red gun for about $70.
    I use one with a high max temp because I like to measure exhaust manifold temp rather than use my finger. This is handy for checking each cyl is running the same mixture as its mates.
    There is a bit of a method for measuring shiny things or water, but once you come to grips with that , its easy.
    I use mine for....
    Water temp,
    beer temp(When I forgot to cool it and have it in the freezer and want it NOW)
    wheel baring temp,
    tyre temp, (inside, middle and outside),
    cooling sytem temp,
    Surface temp after heating surface prior to painting.
    PS fluid temp
    Jo
    1000+ Posts michaelr's Avatar
    1,393
    Or less than $25 from Hong Kong :
    http://www.ebay.com.au/itm/170728203...84.m1438.l2649
    Michael
    Member, Citroen Car Club NSW
    8,378
    Quote Originally Posted by michaelr View Post
    Thats Ok for cooling systems, and at a good price, but no good for exhaust temp readings
    Temp range,-50- 380 C.
    The Digitech one from Jaycar is rated -50 - 550 C.
    Jo
    Dec 2010
    258
    Thanks for the suggestions, Jo and Michael.
    con
    con is offline
    sydney, nsw, australia
    496
    Quote Originally Posted by Citquery View Post
    This is the one I use. It does most jobs competently -
    http://www.altronics.com.au/index.as...=item&id=Q1282
    con...
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    That's a practical one con, its best feature being the 6:1 optical ratio.
    Chris, that would be a good one.
    If you wanted to outlay less, then here's another option
    Jaycar
    QM-7225 @$34.95
    This unit is cheaper being more compact and able to be held in cramped spaces where it is most useful.
    It will also perform as much as you are ever likely to need without a massive expense. Optical ratio is only 1:1.
    Now, for the real budget minded owner out there, try this one from eBay
    http://www.ebay.com.au/itm/Mini-Digi...item19ca11827f
    At $15 with a 2:1 spot ratio, including postage, another option.
    The gun type is inconvenient under the bonnet of a D.
    Doubtless there are others, I have one bought from the US, a few years ago, made in China, accurate and calibrates perfectly. A little more expensive than the one above.
    Hope this helps.
    Dec 2010
    258
    Default pyrometer
    Thanks again for your suggestions everyone - I decided that spot ratio and the ability to get into small spaces were two key criteria, so I've ordered the $60 job from WA.
    Dec 2010
    258
    Great service from Altronic in WA. Delivered to Adelaide within 24 hours. Now to see how well it works.
