air horn question
Results 1 to 9 of 9
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    754
    Default air horn question
    The air horns fitted to a CX have a compressor with an oil hole covered with a cap. When I up end the compressor with my finger over the oil hole there is no trace of any oil.
    What type of oil should I put in and how much please?
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    Fellow Frogger! Techbuy's Avatar
    Dec 2010
    West Ryde Australia
    238
    Quote Originally Posted by rmac View Post
    I have not seen any recommended oiling anywhere, so i just did this.
    A couple of drops of sewing machine oil about once a year and it seems to keep it going.
    Colin
    1975 DS23 IE Pallas Auto
    1972 D Special 4Sp
    1/2 a DS23 Auto
    www.ds23.com.au
    Had a 1974 D Special 4Sp (by now reborn as a Toaster)
    16,702
    Yeah any lightweight oil will do. To be honest it's the trumpet side I find play up. Fill them with inox and let them rip ..... (the horns that is) and they come good. Of course I didn't hook them to the air compressor and use 120psi to do this (don't forget your ear muffs............ damn there loud!!!).
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    I've been using a few drops of LHM, it seems fitting and works.
    Pneumatic tool oil is probably the pedant choice.
    CitroŽn Tragic UFO's Avatar
    9,786
    I found that clearing the trumpets with a compressor can be, well, interesting. The neighbours at XM Driver and XM Mechanics must have thought a train was coming through their back fence!
    11,220
    I have a spare if you are desperate.
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    754
    Thanks for the offer John. I'll see how this one goes after I put a few drops of LHM.
    Thanks for the suggestions from everyone. I'll go with Richo's idea - have it close to hand.
    Current Cars
    1991 Mazda E2200
    1000+ Posts arunine's Avatar
    Port Denison WA 6525
    1,046
    LHM dissipates very rapidly so is of no use. I had a slight leak on my friends driveway and in 3 days there was no trace of it.
    DS 21
    C4 HDI
    Piaggio Fly 125
    Jan 2006
    1,445
    arunine
    Would you consider comparing your friends driveway with a compressor bushing to be a realistic analogy?
    The LHM will be taken up by the bushing due its relatively low viscosity.
    Ross, a few drops of LHM once a year, or when I think of it has worked for the past 5 years or so.
    It was not working prior to the LHM application. I've pneumatic oil for air tools on hand, if I prefered its application.
    I would not recommend LHM as a cure all, simply a working whimsy.
