Buying Rear Arm Bearing Kit for Xantia
    Preston, Melbourne
    279
    Default Buying Rear Arm Bearing Kit for Xantia
    Hi There,
    Can anyone let me know where and how much you got the aforementioned? Did you get the kit or just the bearings? I'm in Melbourne BTW. GSF Ebay was about $180del. pair. Eurocarcare.net was $145 del.
    Thanks,
    Leith
    16,716
    I'll search for the number. You should be able to buy them from your local bearing store for about $25 each (hopefully Rob will have recorded the bearing number for that as well). They should be the same bearing as CX front arms, CX rear arms, BX rear arms, XM rear arms and Xantia rear arms.
    Preston, Melbourne
    279
    Thanks, mines a hatch BTW, are the wagons different? Is it better to get seals and spacers - or not?
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,047
    Hi leith,
    I bought some rear arm kits for BXs from Eurocarcare a couple of months back. They used a sub-contracted form of DHL shipping that loses its tracking capability and there was a big mix up with documents so they took weeks to get here. GSF shipping is always quick but you can run into problems with their customs agents in Australia trying to get their additional cut. You can do a self declaration through Customs though to get around this. (search for this on other posts.)
    The BX rear arm bearings I was replacing were almost non-existant (see Frog BX16V resto thread) so we needed new seals, endcaps etc and it goes together much nicer with all new bits. So it depends on how worn your Xantia arm bearings are. If the rear arms are at an angle then I would recommend the kits as the seals will most likely be damaged. It also works well to use a press. The one the boys said I had to buy from Supercheap worked much better on Frogs rear arms than the hammer method I have previously used.
    Xantia wagon rear arms bearings are bigger than sedans but seem to be the same size as Cx and XM wagons. I must look at my Xantia wagon bearings before it is too late for a simple replacement.
    Ken W
    602
    the SKF code for the sedan arm bearings is 24000. When i went to a local SKF shop, they told me there is no such code .... when i got the bearings from GSF in a SKF box, the code printed on the box is 24000, go figure !!!
    Don't remind me!
    16,609
    Post their website revamp, GSF are effing useless unless you have a knowledgeable contact to phone at one of the stores. They - through these website changes - achieved the dubious "success" of being criticised by pretty much every marque forum they offer parts for.
    BTW the bearing number you want to cross reference is on the bearing; the box frequently differs.
    Ken W, I have two spare of the plastic "dumbell" inserts 5179.13 used when renewing the wagon bearings - they are wholesaled in bags of four. You can have them well under local price, and I will refer you to a cheap supplier of the correct bearings - only a mug pays $20+ each. However the crush tubes, end bushes and shim kits, plus outer seals need to come from PSA when doing a wagon.
    Last edited by addo; 3rd December 2011 at 10:52 PM. Reason: Work around stupid spellchecker/censor.
