D Series Fuel Inlet Fitting Fix Kit
Page 1 of 4 1234 Last
Results 1 to 25 of 97
Like Tree23Likes
Thread: D Series Fuel Inlet Fitting Fix Kit
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    Default D Series Fuel Inlet Fitting Fix Kit
    The repair kit to replace your leaking (or potentially so) fuel inlet fitting is now to hand.
    The kit fits either the Weber as fitted to the later 21 and 23 engines as well as the Solex fitted to the D Specials. If your D was built from 1966 to 1974 then this kit fits.
    It consists of
    1 Excellent quality,HSS cutting tap to cut a thread for the new fitting. NO drilling required.
    1 fuel inlet fitting
    1 small piece of PTFE tape, better known as plumbing tape.
    No special tools required, a shifter will work on the square head of the tap
    This will be packed a tidy little snap lock bag and posted to your address
    for $25.
    The original fitting will look like this, it can fall out, removal by twisitng with a pair of pliers usually works fine.
    I recommend removing the carburetor top and then tapping the thread required,
    BUT others will simply slap some grease on the tap
    then gently and carefully, making certain the tap is square to the hole,
    turn the threading tap a couple of turns, remove the tap, clean off the swarf,
    put some fresh grease on, thread some more until the job is done.
    At the very least, remove the filter nut at the top left side of the unit and block
    the access. You can also gain access to clean out swarf.
    A small amount of thread tape, probably one wrapped turn will be sufficient.
    then thread the new fitting into place, with your 11mm or 7/16" wrench.
    I prefer to also use a hose clamp on the new fitting,
    even though the barbs will hold the plot, no worries.
    Payment may be by money order, cash dscreetly hidden in an envelope, Paypal or Direct Deposit to a bank account. $25 includes postage.
    Extra fittings @ $8 each if you have more than one car and are buying a kit.
    New Zealand owners, please add another $5 for postage. Australia Post is obviously doing it tough these days.
    Please PM or email me [email protected] for snail mail or Paypal address.
    Thanks for your support.
    If this manages to prevent just one under bonnet fire I'll be a happy bloke.
    Last edited by richo; 23rd November 2011 at 06:58 PM. Reason: clarification and detail
    Citroën Tragic UFO's Avatar
    9,666
    Good on you Richo.
    18,760
    Contents deleted as requested by thread originator
    Last edited by robmac; 23rd November 2011 at 10:16 PM. Reason: Richo's kit won't fit pugs
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,025
    Richo will these things work on a 32/34 PBIC/
    Cheers Gerry
    16,333
    Cheers Gerry
    Yep, if there the same as Bob kit I'm glad Richo took this task on .... Some of us are known for saying " I'll do that " .................... and never getting to it
    Jan 2006
    1,445
    Same as the "Bob" kit, as explained in the thread from a month ago.
    One kit remains unsold, plus a few fittings.
    All kits in the post as of today.
    Thanks to those who asked for them to be made, then supported this effort by buying the product offered.
    Jun 2003
    Lauderdale, Tasmania
    2,884
    This is what happens if you don't replace that loose brass pipe.
    Attached Thumbnails Attached Thumbnails D Series Fuel Inlet Fitting Fix Kit-aut_0014.jpg   D Series Fuel Inlet Fitting Fix Kit-aut_0009.jpg
    Jan 2006
    1,445
    All kits sold at this time.
    IF there is sufficient interest in another batch (of 10) it will be considered.
    Interest would be by way of commitment via this thread.
    Pre-payment is okay and appreciated, once the numbers required are reached.
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    748
    Can you put me down for TWO of the next batch please?
    They look like a great remedy to a real problem. Far better than the wire holding the lines in place currently on my carbies.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    80
    I would like two of the kits as well. This is a great fix to known problem which could occur at any time with such old cars.
    Richard
    castlemaine
    503
    Richo, put me down for 1 kit plus 2 fittings.
    thanks, roger
    Jan 2006
    1,445
    Thanks to the three "Rs" (Ross, Richard and Roger) for putting their hands up.
    I've placed the order for more taps, they'll be three weeks or so to arrive.
    Meantime I'll set some time aside to start machining again.
    Please, keep the request/orders coming.
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Quote Originally Posted by richo View Post
    Hi Richard
    As previously discussed put me down for 1 kit plus 2 fittings.
    Philippe
    748
    Can I amend my order to one set with four fittings please? One 'tap' set with four 'pipes'.
    Current Cars
    1991 Mazda E2200
    8,161
    Icon12
    Hi Richo,
    As discussed I'll put my name down for 1 kit - it's for a spare carby so I can go to the bottom of the list if orders are filling fast
    08 C5 X7 HDi very Noir
    Fellow Frogger! Dave Rogers's Avatar
    Frankston Melbourne Australia
    259
    Hi Richo, As discussed in our PMs I'd definitely like one kit.
    Dave
    74/75 DS23 Pallas 5 Speed Carby
    83 2CV Charleston
    79 GSA
    03 Peugeot 406 Hdi
    01 Renault Scenic
    Dec 2010
    258
    Default Weber carby threaded fuel inlet fitting
    Richo,
    I'd like to order one too!
    Jan 2006
    1,445
    Thanks for the interest, need two more orders for kits and I'll be ordering the taps, which take three weeks to arrive.
    The machining will begin as soon as the orders are received.
    I will ask for payment and address details once the order is underway. Then they can be sent in one batch.
    Thanks for the support, this will be the final batch.
    UPDATE 25/11:
    I think the final orders are to hand, just waiting confirmation from a NZ owner.
    Taps are ordered as of now and the machining of the fittings will be completed
    on the weekend.
    748
    Transferred $50 to your account today. Thanks very much Richo.
    Current Cars
    1991 Mazda E2200
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,131
    Well there's mine done! The tap is excellent.. it was like tapping butter. Perfect fit.. no more leaks, no ugly wire!
    Many thanks Mr Kennedy for your time and skill. Always appreciated.
    Matthew
    Attached Thumbnails Attached Thumbnails D Series Fuel Inlet Fitting Fix Kit-100_0705.jpg
    Tadpole Elomenonp's Avatar
    Sep 2005
    Christchurch, New Zealand
    13
    UPDATE 25/11:
    on the weekend.
    Hi Richo,
    I have received confirmation of the order for two kits and four additional fittings as discussed.
    Cheers, Praveen
    1000+ Posts michaelr's Avatar
    1,393
    Thanks Richo,
    I picked up the fittings today from the PO. I have the old pressed-in fitting removed and frankly it did not take much effort to do so even thought the previous owner had refitted it using epoxy adhesive. I am glad I had wire on it!
    I have given the carb a good clean and blasted it with baking soda. It has cleaned without making it shiny which suits me fine. The main advantage is no residual grit... just a funny taste in the mouth.
    Tomorrow I will fit the new part plus a new carb gasket kit. There are two small O rings in the kit for which I have not yet found a home (but I will look more closely) and the needle valve is of a different design but has the same dimensions so should be fine.
    Michael
    Member, Citroen Car Club NSW
    Jan 2006
    1,445
    My pleasure Michael.
    Drinking from the bowl of a Weber must be a unique experience, or were you licking it clean?
    Hope the fitting all goes well.
    Fellow Frogger! Amopallas's Avatar
    140
    Hi Michael. Are you sure you have the right kit for the Weber 28/36 DMA,DLE carburettor ?. When I bought mine about 10 yaers ago from a place in Thornbury, Melbourne called Thornbury Carburettor Services,there were two paper gaskets( For different types of 28/36). a needle and seat,of the same type and dimension as the original,and a small paper gasket,rectangular in shape,but no rubber O rings. I hope you have good luck re fitting the 4 nuts that secure the carb on the manifold,the rear nuts close to the cylinder head,are a real pain,because there is no room to use a socket/ring spanner or open end spanner. Cheers Joe
    1975 Citroen DS 23 Pallas
    1,393
    Quote Originally Posted by Amopallas View Post
    Thanks Joe,
    Those rear nuts are a real pain aren't they! Then again it is a Citroen.
    Yeah, I think the rubber bits were a ring in. The rest of the parts are good though and the needle valve is clearly an improved design (it has a spring loaded ball that makes contact with the top of the float) and yes, it had the two top gaskets to cover both models. Strangely I bought it on Ebay from a vendor in Holland for around $40 delivered but on arrival the packaging says "Packed in Australia".
    http://www.ebay.com.au/itm/310355530...84.m1439.l2649
    Anyway, the car is running well now and hopefully it has improved the economy and reliability. Not so likely to burst into flames either with a proper screwed in fuel fitting!
    Michael
