DS Instrument Cluster - 1970>
Page 1 of 4 1234 Last
Results 1 to 25 of 90
Like Tree16Likes
Thread: DS Instrument Cluster - 1970>
    7,967
    Icon2 DS Instrument Cluster - 1970>
    Prompted by a request for help from AF member ramonm, typical problem broken corners on his instrument dash cluster.
    Word to the wise, the cluster is fixed in place by four stainless screws, the cause of the broken corners is simply these are overtightened. The screws actually only need the slightest of tension, the cluster cannot fall out, it's held by the three loom connectors and the speedo cable.
    broken DS 23 dash
    I'm in the process of bringing a few clusters back to service, and finding several parts are starting to look pretty shabby after 30+ years.
    There are a few configurations dependent on model trim levels, and I suspect what might have been available at the factory at the time of assembly.
    In the pic I have three variations, the top one has a chrome trim on the raised dial faces, the centre is without any bling (more likely seen on base spec models) and the lower face is one I'm working on for ramonm - this had the satin foil treatment, I have re-painted using a plastic primer (clear) and pressure pack silver sprayed into a saucer and using a fine sable brush hand painted.
    I know there is a foil kit available as a self adhesive, but I wouldn't be too confident that the end result would be too good in our Aussie sun.
    On close inspection the clear dial faces are quite scratched, it would seem in an attempt to clean over zealous owners have actually put concentric scratches into the plastic. The only way to fix this is by removing the clear face, I've done this with a few and had great success using Novus Plasic Polish - this is a three part process but really does polish out the scratches.
    The next problem I've seen is that the symbols on the left dial face are starting to fade away... this one is not too bad but you can see the Low beam/ indicator triangles and temp symbols are on their way out. [BTW, this one has not been polished but will get the treatment]
    I've scanned and redrawn the left dial face, from a good dial I have...
    Redrawn in vector format...
    ...and screenprinted the symbols, the red STOP seems to survive, but I have this on screen in case...
    Now maybe to the point of this thread, there must be a bunch of broken discarded clusters out there, if anyone would like to donate or accept some small payment, I'm interested in taking them apart and recycling the useful parts. The chrome rings at the base of each dial seem to degrade and good replacements would be useful.
    In this pic the left rim is quite good but the one on the right has seen better days
    I don't need the whole cluster, just the broken black face, but would be happy to take whatever...
    With a small stockpile of usable parts I would then be happy to help others rejuvenate their clusters - and dependent on what is required maybe a small fee
    Once I get Ramon's cluster face back together I'll update this thread
    Attached Thumbnails Attached Thumbnails DS Instrument Cluster - 1970>-symbol_face_removed.jpg   DS Instrument Cluster - 1970>-faded_symbols.jpg   DS Instrument Cluster - 1970>-left_dial_scan.jpg   DS Instrument Cluster - 1970>-vecor_art_colour.jpg   DS Instrument Cluster - 1970>-dial_on_screen.jpg   DS Instrument Cluster - 1970>-printed_dial.jpg
    Lasya and dino like this.
    08 C5 X7 HDi very Noir
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    600
    Nice work, Chris!
    As with everything you seem to do.
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    1000+ Posts michaelr's Avatar
    1,395
    Great work Chris.
    I am wondering about the broken corner problem. Is it possible that when the panels left the factory there were spacers behind the screws? Maybe a piece of tubing on the screw which would make the screw captive? I will experiment with mine to see if something can be fitted. It would allow the screws to be tightened a little to avoid rattles.
    As you know I have had my cluster apart this week with great results thanks to your input. One thing that bugs me though is that the high beam warning light and the other blue light warning are very dim. Any ideas why?
    On another matter I am just amazed that the Citroen designers when they designed this last dashboard for the DS managed to obscure half the warning lights with the steering wheel rim, unforgivable given that it had a single spoke presumably to improve visibility. They really did lose the plot.
    Michael
    Member, Citroen Car Club NSW
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,453
    I'll send one off to you Chris, the instruments are probably good, but didn't meet the richo quality control requirements or the auction description. Pedant that I am.
    7,967
    Icon3
    Quote Originally Posted by michaelr View Post
    Great work Chris.
    Hi Michael,
    Yes, maybe a rubber washer fixed to the dash side of the hole, once you feel the tension of the rubber squeezing your done?
    The High/Low beam lenses can be replaced, I have one that I am looking to get a better lens for. The bulbs are supposed to be 2w (read dull) otherwise the heat can melt the plastic. Looking for a plastic that might withstand a little more heat/ more transparent green and blue/ or cooler bulbs.
    I have heard of someone here fitting brighter but cooler LEDs - these look like a possibility - T653SMD2P ?
    http://www.brightlightautoparts.com/...entGlobes.html
    Quote Originally Posted by richo View Post
    Always to be relied upon - what can I say
    Thank God I'm a Fwenchman harrisson_citroen's Avatar
    Feb 2002
    Coolum Beach
    1,530
    Chris, can I please use it as my avatar?
    7,967
    Icon3
    Quote Originally Posted by harrisson_citroen View Post
    The colour is a little bright, I could tone it down a bit for you and with some arm twisting we could have flashing indicators
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    642
    The late Paul Smith did some dramatic work on his DS23 and had the main and high beam sections so bright it was almost annoying! I vaguely remember him talking of a combo of cleaning AND sanding the blue and green bits down to a thinner more transparent section.
    Citroen Car Club of New South Wales member.
    My Citroen ID21F can be seen here http://www.flickr.com/photos/frontdr...7605999522616/
    Feb 2002
    Coolum Beach
    1,530
    With flashing indicators, and the red centre illuminating occasionally?
    7,967
    Icon3
    Sheesh, ya' don't want much...
    Attached Thumbnails Attached Thumbnails DS Instrument Cluster - 1970&gt;-ds-dial.gif
    Feb 2002
    Coolum Beach
    1,530
    Holy Guacamole! How cool is this?
    Much appreciated Chris, thank you.
    Now, to stop those other buggars flogging it....
    tweed heads
    1,332
    Default like your work
    must admit i was wondering what qots spelt in french till i worked out it was STOP back to front
    Jan 2006
    1,453
    Excellent avatar, I'm very nearly envious, almost.
    Hey it looks great, much better than an old Safari.
    Fellow Frogger! pottsy's Avatar
    Melbourne, Northern Suburbs
    948
    Hah! It looks very much like mine on Moby Dick. I modified things to have either right of left flasher pilot lamp on with the corresponding indicator. I bever liked the original which just flashed both together.
    Great work, all of you, but especially Chris, the Graphics Wizard.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    2006 307 Auto 5 Door ("Spike" Mrs P's)
    1974 D Special Manual Sedan ("Moby Dick")
    2006 C5 HDI Wagon Auto ("Mephistopheles")
    1957 Slough 2CV ("Alphonse") Waiting in the wings
    1982 2CV6 ("Gaston") On the road! (Woohoo!)
    Feb 2002
    Coolum Beach
    1,530
    Richo,
    Nicely said, but no, nothing looks better than an old Safari
    7,967
    Icon3
    Quote Originally Posted by pottsy View Post
    Cheers, Pottsy
    That really bugs me too, I have clusters that illuminate both and others that just illuminate the direction you select. I'd love to know how to change to the latter...
    Feb 2002
    Coolum Beach
    1,530
    And I'm sure Chris could be talked into illuminating those stoplights and blinkers on the Safari avatar!
    DS
    DS is offline
    642
    Some earlier 3 dial dash units had individual flashing arrows for left and right. Find one of those!
    Mort Subite likes this.
    Feb 2002
    Coolum Beach
    1,530
    Quote Originally Posted by DS View Post
    When I grew up in France and rode countless family IDs DSs , as well as Taxis, etc.. I am pretty sure the arrows were either left or right. I think both illuminating is a fault that develops with old age somehow.
    Although not 100% sure, but almost.
    7,967
    Icon5
    Possibly? I can't check 'cause I've no guards or rear trumpets on the car
    I did check one cluster with the car in this state and it not only illuminated left and right but also the red light between the two [<>] which I would expect to see with hazards on?
    Once the car is back together I'd like to get it working like Pottsy's/ your avatar
    948
    On Moby the two lamps were paralleled by the printed circuit (as I recall, it was a few years ago). I isolated them and ran new wires to the relevant connections on the indicator switch.
    A bonus to doing this is that if I ever need to I can use a simple 2 pin flasher unit rather than the original three pin jobbie. (The third pin is a "common" for the pilot lamp, in the original case both together.)
    Not a difficult job to do, but only if you don't care about keeping everything original as the maker intended.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,306
    Regarding the high beam light, they should be dim. The last thing you want is a bright light when running in high beam. The CX's high beam indicator can hardly be seen in daylight but at night bright enough.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    1,395
    Quote Originally Posted by Greg C View Post
    Ah yes, I agree, but my H/B light is so dim as to be almost invisible even at night. I have had the whole assembly apart and cleaned it all, and even check and changed bulbs, but no big improvement.
    Michael
    7,967
    Icon12
    Cheers, Pottsy
    That's a modification I'd gladly undertake, It makes much more sense when negotiating a roundabout etc. and of course it is reversable even if another cluster is required. My car could never be seen as original, so many changes from when it was driven off the showroom floor.
    DS
    DS is offline
    642
    I've been out in the garage looking at the three units I have. Two are clearly from later model cars as they have the mount for the optical fibre pick-up. The other is stamped 1970.
    I'm now kinda keen to take the back panel off them to see what differences there might be on the circuits panels.
    Its easy to see what position the indicator stalk is in to see where you are signalling even with the two flashing.
    My 1969 dash has one green flasher on the left of the speedo that flashes for left or right. Often passengers tell I'm supposed to be turning right as they only see a left bit flashing!
