The TRACTION! Appreciation Thread - Page 6
Page 6 of 6 First ... 23456
Results 126 to 148 of 148
Like Tree17Likes
Thread: The TRACTION! Appreciation Thread
  1. #126
    15,313
    last traction leaving the factory
    https://www.facebook.com/oldtimerkon...1806571505116/
  2. #127
    15,313
    Big 6 right ? I love the wheels
    Citroen TRACTION 11 C 6 CRISTALES
  3. #128
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    2,591
    Bit hard to say exactly but the front guards and bonnet extension panels look wrong for a six. That does not mean that someone didn't try to stuff a six engine and gearbox into it. My bet is that it is a 1938-9 Familiale with the four cylinder engine in it. The add description is misleading! 11 C6 ????????? Where did they get that from?
    More likely an 11F or if it is an 11C it would have to be the Commerciale. There is no way of telling from just that photo!
    Cheers Gerry
  4. #129
    15,313
  5. #130
    2,591
    He incorrectly describes that car as an 11BL when it is in fact an 11B Normale.
    Cheers Gerry
  6. #131
    1000+ Posts FIVEDOOR's Avatar
    Jun 2011
    Brisbane Qld
    17,877
    One for sale in Finland
    Described as BL11
    4D Berline
    First registered 1946
    1910 cc
    The car has been on what they call Museum registration since 2004
    This was the only photo
    Every day is a good day
  7. #132
    2,591
    Yes you can see the early type of front seat with the exposed chrome rail. Note the semaphore signals mounted in their own little boxes on the lower part of the A pillar! Obviously not Lucas units ----probably of Continental manufacture!
    Cheers Gerry
  8. #133
    Fellow Frogger! Greg's Avatar
    MAITLAND NSW AUSTRALIA
    451
    Hi Guys
    The car is a a 1956 11C, a Commerciale, (with pre war Pilot wheels), the same as the last traction to leave the factory in '57
    Best regards,
    Greg
    We Have:
    We Had:
  9. #134
    2,591
    Quote Originally Posted by Greg View Post
    Hi Guys
    Best regards,
    Greg
    Correct!
    Cheers Gerry
  10. #135
    Jun 2014
    148
    Yes I have seen that kind of damage on a traction before. They are really very strong against frontal impact. Also side impact.
    I inspected a car that was for sale as a parts car. It had been hit in the drivers door by an MG TC. The MG driver was drunk and T boned the Traction. The lower sill moved 3 inches and the centre of the door pillar moved six inches.
    The TA driver received a bruised arm, and the MG was totally destroyed. The engine was 50 yards down the road and the chassis split apart. The only reason the MG driver survived was the fact that being drunk he rolled after being thrown from the car.
    Another TA I saw was in a wrecking yard. It had been hit front on and the car had buckled upwards at roughly the engine side damper mounts. The passenger compartment was totally intact but the front doors would not shut and unfortunately the driver of this car was impaled on the steering column.
    Probably has a lot to do with the hidden 'angle' L section steel welded to the inner sill & running the length of the door section. This is covered by the outer sill (rocker) panels. I believe the designers were a bit nervous as it was one of the first monocoques so built in some extra strength.
    Regards, Baldrick
    may all your plans be cunning ones,
    Baldrick,
    fleet: 1989 Peugeot 505 GTi Wagon
    1969 Peugeot 404 Sedan
    2003 Smart 452 Roadster
    2005 Holden Astra Equipe
    1953 Citroen 15CV (under Restoration)
    1953 Bristol 401 (under Restoration)
  11. #136
    2,591
    Have a look at a DS sill beam. They are triple strength as well! No nervousness involved at all just common sense and no cheapskate solutions. ------After all the car was built by engineers not a committee where accountants rule!
    Cheers Gerry
  12. #137
    Melbourne, Australia
    209
    1974 Citroen D Special (Blanc Meije)
    1989 Citroen 2CV 6 Dolly (Plum & Custard)
    1995 Citroen XM Series II V6 (Vert Vega)
    (Previously owned Frenchies - 1976 Citroen GS 1220, 1997 Peugeot 306 XSi)
  13. #138
    Fellow Frogger! fnqvmuch's Avatar
    port douglas
    586
    The TRACTION! Appreciation Thread-1.jpgThe TRACTION! Appreciation Thread-2.jpgThe TRACTION! Appreciation Thread-3.jpg
    rather than a new thread might i bump this one just to get a date for this brochure?
    Hot Cars
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
  14. #139
    Fellow Frogger! Trading Estate's Avatar
    482
    L'Album de La traction suggests the 11D 4 cylinder motor was fitted from May 1955.
    '04 Megane
    Gone but not forgotten
    '71 16 TS, '72 16 TL, '74 15TS,'82 20TS Series 2, '85 25 GTX. '49 L15,
  15. #140
    port douglas
    586
    thank you very much for that - way beyond my references, or wikipedia ...
    makes it quite a late Kow, i'm thinking
  16. #141
    Dec 2011
    Kyneton
    23
    Gerry,
    My father had a pre-war traction with wires and also a fabric sectioned roof. It was handed on to my grandfather. I found it in later years rusting away in a paddock in Eltham. The wire wheels were handed on to Andrew Rankine.
    Leon
  17. #142
    2,591
    Quote Originally Posted by leon sims View Post
    Gerry,
    Leon
    Was it a mid/dark blue colour? If so I have the bonnet from that car!
    Cheers Gerry
  18. #143
    Dec 2011
    Kyneton
    23
    Too far back to remember but if not black then you could be right about dark blue. Did you locate it in Eltham?
  19. #144
    2,591
    It came off a car that was in a yard on the Eltham Montmorency Road just near the rail overpass!
    Cheers Gerry
  20. #145
    Dec 2011
    Kyneton
    23
    Yes - that was our car.
  21. #146
    2,591
    I keep agonising on whether or not to fit this bonnet to the 11Bl. I have re-chromed the handles and centre strip, purchased new bonnet door handles, and fabricated a replacement rear left bonnet door. The old one was rusted through. It needs a new bracket for the bonnet stay that I obtained from Andrew Begelhole to be welded into place. Then it will be ready to go!
    On the subject of pre-war Citroens, our first Traction was a 1938 11CL2 from Slough. Dad purchased the car in 1954 from Shields Motors in Spring Street. The car was the personal vehicle of Mr. Lyle Nagle, one of the Directors at that time. We ran that car until the clutch cable broke in the middle of a down shift to second and the shock opened up the gearbox casing and bell housing. It was finally cut up in 1964 despite many protests from myself and now lies entombed under the Eastern Freeway. I still have the instrument gauges, cylinder head and the carby/ manifold assembly.
    Cheers Gerry
  22. #147
    15,313
    There is some nice pictures here.
    French Accent: Riding In A 1955 CitroŽn Traction Avant - Roadkill
    Is that what the french car interiors looked like when new? The white steering wheel looks odd to me.
  23. #148
    2,591
    The large boot cars had that treatment across the top of the dash that included the instrument cluster in the window frame. It was painted "Gris Clair" and the steering wheel matches this. Earlier steering wheels were black. Note that the seat material is a mix of vinyl and striped cloth, and that the striping is different from the 1950 and 51 cars. I think that they were trying to make the interior a bit more durable. There is even what looks like a vinyl panel on the firewall bulge.
    Cheers Gerry
