C4 Ignition Key problems
Results 1 to 7 of 7
    brisbane
    35
    Default C4 Ignition Key problems
    Hi Guys
    the ignition key for my '08 C4 at 60Ks is getting difficult to use to lock and unlock
    any suggestions ???
    Melbourne, Victoria.
    1,389
    Hi Pete,
    here's what you do.
    1. Make sure you don't have lots of keyrings and crap hanging off the key, if you do, get rid of them.
    2. Puff some powdered graphite into the door locks and ignition lock, work the key in and out a few times to get it working around inside.
    3. Hope that no-one has ever squirted any oil or liquid lube into the lock.
    You shouldn't have any further issues.
    Cheers...George 1/8th.
    brisbane
    35
    thanks George, but it's the "REMOTE" I'm having the problem with
    9,769
    Battery perhaps??? Or do you mean the key part is difficult to unfold/fold back into the case? You would have to take it apart to fix that and it may be better left to a technician who has done this before. Worst case, short of buying a new key, is to open it out and lock it there somehow.
    don
    don is offline
    Fellow Frogger! don's Avatar
    Mayfield Newcastle
    436
    this is an easy fix
    Get onto Ebay.co.uk Buy a fob case ( the one with the Headlight Mid Button) and replace the inards you will need to remove the UK battery lugs (plastic bits) but its a really easy fix Chip anD battery fit snug and tight
    Cost me $21 AU and 3 minutes dexterity.
    brisbane
    35
    thankyou Don will do that
    1,389
    In that case,
    dismantle plip, check battery, check contacts, replace battery, remove circuit, inspect with microscope to find any dry joints, resolder dry joints, reassemble. Fixed.
