Ds , dv dx??
Results 1 to 7 of 7
Thread: Ds , dv dx??
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,222
    Default Ds , dv dx??
    Hi there
    Been looking at parts suppliers. When they refer to the DV or DX engine what does that mean. My 1970 D SPecial would be what?
    MAtthew
    16,414
    It's the engine type .... take a look at your block. It should be cast into it. eg; DX5 == DS23 ie DY == long stroke etc...
    1000+ Posts michaelr's Avatar
    1,393
    The plate with the engine number and type is below the water pump and the belt driven high pressure pump (if you have one) and near the clutch cable (on a manual car!).
    The one in the attached photo is a DX, so an early DS21 motor.
    Michael
    Member, Citroen Car Club NSW
    Los Angeles, CA USA
    1,955
    All the 5 main blocks are essentially the same.
    Yours should be a DV. I think they went to DV2 in 1972.
    At this point in time (2011), the block designation might not mean much. Many 1950 blocks have been fitted with 2175 liners and heads so service history and records could become very important forensic tools on many cars.
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    1950 blocks? Made in 1950? :-) Don't you mean 1985cc?
    mnm
    mnm is offline
    Dec 2010
    3,222
    Quote Originally Posted by daffyduck View Post
    Thanks for that.. the reason I ask is I need some new rubber tubes for the crank case breather.. the one that runs off the air cleaner and meets at a T pipe.. seen one for DX and DV so i was wondering if it made a difference.
    Matthew
    Fellow Frogger! Mort Subite's Avatar
    620
    Quote Originally Posted by mnm View Post
    Matthew
    Difference? Not much. Its the engine designation and HP delivered to the gearbox.
    Most of the pipes are the same from engine to engine in the last models especially for the breather tubes, etc.
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
