The "Special Tool" thread
Page 1 of 6 12345 ... Last
Results 1 to 25 of 135
Like Tree14Likes
Thread: The "Special Tool" thread
    16,426
    Default The "Special Tool" thread
    Hi Guys,
    if you have drawings to create a "special" tool as required for working on our cars.... Post it here!! Even better, if you own any "special tools" if you can measure them up we will request vince does some technical drawings for them so anyone can make one. If you have found a tool that will work in place of a required special tool. Let everyone know! (eg: spanner to adjust later DS brakes, tool to back off clockwork DS pads, tool to extract CX driveshaft over it's snap ring). photos and diagrams of factory tools to aid creation or identification of the tools is always welcome.
    16,426
    Here is the CX lower arm tool kindly drawn up by Vince:
    http://www.shanescitshed.com/arm_tool/ASSEMBLY.PDF
    http://www.shanescitshed.com/arm_tool/EXPANDER.PDF
    http://www.shanescitshed.com/arm_tool/KEY.PDF
    http://www.shanescitshed.com/arm_tool/SPINDLE.PDF
    http://www.shanescitshed.com/arm_tool/TAPER.PDF
    He has offered to draw up any tool we give him the dimensions for.
    Has anyone tried this on a CX left hand driveshaft ??
    http://cgi.ebay.com/INNER-CV-JOINT-P...#ht_799wt_1141
    It would be great if someone has the CX driveshaft puller and rollbar balljoint tall they could take measurements of
    16,426
    XM/Xantia/BX/406/etc lower balljoint tool
    No drawings required for this one. It's cheaply available here in Austraila:
    http://www.toolworks.com.au/j7215-lo...nt-socket.html
    16,426
    Square drive sump plug tool (BX). These are available on ebay UK, or David Cavanagh at french connection has them for about $10.00. See sticky for his contact details. There not worth trying to make when they are this cheap.
    16,426
    Hi Guys,
    I found a cheap flare spanner set today with all the sizes we need (8,9,.10,11,12) on ebay. $36.00 delivered to your door
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=140522129246
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    Those flare nut spanners look fairly good, Shane.
    I am still looking for a flare nut spanner in 9x10. I can find 8x9, 8x10, 9x11 and 10x12. If I could find a 9x10 I could add a 12x14 and I would have every hydraulic fitting on my DS19 covered, and all in 2 spanners.
    Roger
    16,426
    They appear nicely made. The bit that appeals is I've never seen a set with all the sizes we need to cover earlyDS/late/DS/CX/BX/GS/etc.... this set does. They would be better if they were single hex (gripped the nuts but the sides, not the corners).
    I clicked "buy it now" and received an email 2hours later saying they had already posted them... so they appear to be quite a prompt ebay shop.
    picture link to spanners:
    http://www.auctiva.com/hostedimages/...0,0,0&format=0
    8,185
    Icon12
    Hi Guys,
    Thanks Shane, I've always wanted a set, I ordered a set last night, no email from seller but I guess with the weekend and time difference I should hear from them this evening
    They would have to be better than using open ended spanners that I'm currently working with...
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,069
    I do agree that single hex would be better. It is so easy to round off the corners of flare nuts particularly the small sizes. I purchased a cheap single hex set years ago from an 'el-cheapo' tool purveyor. They of course did not have the 9-11 or 8-10. I was able to purchase those from Ryans in Elizabeth Street in Stahwille brand. These have satisfied my every demand.
    Cheers Gerry
    1000+ Posts michaelr's Avatar
    1,393
    These are hex and only $25.95 from Brisbane.
    I paid that much for one 9mm flare nut spanner from Repco!
    http://cgi.ebay.com.au/CALIIBRE-5PCE...item2562d37b8b
    Attached Thumbnails Attached Thumbnails The &quot;Special Tool&quot; thread-flare-nut-spanners-.jpg
    Michael
    Member, Citroen Car Club NSW
    16,426
    Quote Originally Posted by michaelr View Post
    They look good .... no 8mm though
    1000+ Posts pottsy's Avatar
    Melbourne, Northern Suburbs
    1,024
    Hey Shane, hope you get a good commission. Just ordered a set myself.
    I've got an excellent Dowidat 9/11 spanner I keep in the garage, and a modified 9mm one in the car kit.
    Been after a set like this for a while.
    Thanks for spotting it.
    Cheers, Pottsy
    Buvito Ergo Sum!
    The Fleet:
    2018 C3 Shine ("Oscar" Mrs P's)
    1974 D Special Manual Sedan ("Moby Dick")
    2006 C5 HDI Wagon Auto ("Mephistopheles")
    1982 2CV6 ("Gaston") Seasoned traveller
    1975 GS Pallas ("GiSelle") Next project
    Member Sturla's Avatar
    Nov 2005
    Bergen, Norway
    73
    Default Tool for difficult pipe unions
    Hi. The pipe nuts are often problematic to loosen, they tend to be weak from rust and bonded with whatever aluminium part they are fastened to. I have a tool that somebody made in limited numbers some years back, but images for this exists, for others to give it a go. The point is, the opening is a bit tighter at one end of the hex grip, since the union nuts tend to have less material on them now than when they were new. This way the grip is very tight, and the the union easier to unfasten. I have used it on a lot of rusty pipes, and it is excellent. For 3,5mm and 4,5mm pipe.
    -74 DS23 bvh, -78 CXgti, -85 CXgtiT1
    16,426
    that's brilliant!!! Once you have loosened it the first half a turn, you could then unscrew with a normal flare spanner. Do you know if these are still for sale anywhere?
    We don't have the "frozen line" nut issue as much in Australia. However I have two cars imported from the salty soggy UK here..... Some hydraulic fittings I've had to cut off as they can't be unscrewed
    VIP Sponsor richo's Avatar
    Jan 2006
    Hobart, the other planet
    1,445
    Great tool. I love it, for its creativeness and effective potential use.
    I still find the Stahlwille #14 series does the job for me, as well as a couple of small 9mm Snap-On open enders of vintage heritage.
    Rarely do I use flare nut specific tools, as single hex they can prove inconvenient. Like Gerry, I too have Stahlwille flare nut wrenches.
    There are ways of persuading these nuts to let go, even in the toughest situations.
    Of course there is no substitute for having a flaring tool and new nuts to replace a piece of line which has corroded.
    16,426
    Quote Originally Posted by jackafrica View Post
    I have one of the 3.5mm flaring tools too. They appear less than ideal working with original "hard" metal lines (that rusted away 30years in the UK). The soft pipe we use these days it is very effective on though. I must buy in some of cupro-nickel pipe and end pieces someday
    Jan 2006
    1,445
    My experience has been the opposite.
    I prefer to replace with the original lines, cut down as required from other prts of the car. No problems or difficulties to date.
    Colour of the cupro nickel lines does my anorak head in.
    Now setting up plating equipment, should be interesting and keep me amused for ages.
    Tired of platers promises and failure to deliver.
    Warrnambool
    2,346
    You braggards! I make do with Snap-on, which feel nowhere near as good in one's hands. One day I might find some Stahlwilles at a good price.
    True, once you have a tight nut loosened, and if you then keep everything in good order, a good open end spanner can do the job. But I often find the nuts are already butchered, so it is as well to do the initial loosening with a flare nut spanner anyway. This is where Sturla's tapering tool would be good.
    For access to tight spots I have contemplated buying a set of crowfoot wrenches, basically flare nut sockets, but rarely does one find a 9mm one in a set. Instead, I bought a cheapish set of Blackhawk flexi-head flare nut spanners that included 9mm.
    Stahlwille 14s are good, but the now discontinued 15s were better. They had the same ring end as the 14s, but their open end flared out slightly so they slip more easily onto the nut.
    Roger
    16,426
    I think Roger has a milling machine ??? Lets all place our orders for one of those spanners :poke:
    16,426
    actually you could probably make those spanners with a lathe by mounting the spanner on the toolpost and putting a milling cutter into the chuck... How to cut the taper though ... hmm.... you see you'll only be able to mount it on the toolpost horizontally.
    10,813
    Hi Guys,
    Many thanks Shane. Needed that set! Ordered.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,412
    Default Facom
    I came across a set of these at a garage sale and they are the best spanners I have found for difficult access places.
    http://www.generaltools.com.au/facom.html
    (Not me in the Photo).
    Attached Thumbnails Attached Thumbnails The &quot;Special Tool&quot; thread-facom_metric.jpg
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    10,813
    Quote Originally Posted by Gamma View Post
    Now THAT is interesting. Thanks very much. I've never seen anything like them before.
    Renault 4CV 1951
    Renault R8 1965
    Jan 2006
    1,445
    They are a ratcheting open ender.
    I have one in 11mm, never been too confident with its use. No longer in the main tool box, has been banished to the secondary box.
    16,426
    I've seen them around too... but always thought "no way I'd round every fastener I try it on" A good quality ratcheting ring spanner would probably be better
