Info wanted GS 1220 cambelt bearing nos.
Results 1 to 8 of 8
    Fellow Frogger! Andy N's Avatar
    NSW
    816
    Default Info wanted GS 1220 cambelt bearing nos.
    Hi, I have searched but haven't found what I'm looking for. I am ordering a pair of Gates cambelts for the GS and want to replace the cambelt tensioner bearings too. They don't have a part number for the bearings so I was wondering if anyone has this written down somewhere?
    Cheers, Andy
    NSW
    816
    Anyone? 33 views no replies!? Fento, Chris.......are you guys there? I can't order until Monday now so will wait until then. The GS is making a weird screaming noise occasionally like one of those souped up V8's whining noise maybe like air whistling from somwhere. I don't know what it is and am not sure the history of the belts and bearings so it will be the most basic step.
    This GS needs much work and I want to take it to Stanthorpe this easter but have little time to get it roadworthy. Other parts needed if anyone has spare; anti-roll bar droplinks, lower arm bushes, cv boot, tie rod inner, Michelin (MXTE) tyres 185/65 R15, front late grill, rear LH taillight/ black moulding later type, steering wheel(unlikely), etc. Most of these I will have to get overseas but just thought I would check.
    Cheers, Andy
    CitroŽn Tragic UFO's Avatar
    9,721
    Andy, are you at the point where you can actually SEE the bearings? Do they have a part number engraved on the side?
    I believe SKF are usually a good source for Citroen related bearings.
    Sydney, Australia
    306
    Hello Andy,
    I can't help with the tensioner bearings part number. However I would like to know for my own benefit.
    I too have just received some Gates timing belts for the GS 1220. It took a bit but the local Bursons came through. He is now attempting to find the tensioner bearings for me. I understand I can get them overseas but a local supplier would be good. Also I have not clapped eyes on the bearings themselves yet to ascertain the part numbers.
    The Gates kit I have for the car is a P/N 5012 it contains both belts (They are different sizes). I guess it comes from Gates UK cause you can't get it here.
    However you can get both belts individually here they are a Gates P/N T025 and T026.
    The T025 belt is a 41093 x 3/4 (ie. it has 93 teeth and is 3/4" wide)
    The T026 belt is a 41105 x 3/4 (ie. it has 105 teeth and is 3/4" wide)
    I got some lower arm bushes (called fluid bloc bearings) from Citroen Andre. Chevronics seemed unwilling to sell me these parts for some reason. They did however sell me several other bits.
    Garth.
    Fixin' Cit's.
    '19 308 GTi
    '15 DS 5
    '74 GS Convertisseur
    In the family
    '51 Traction
    '08 C5 X7 V6
    Previous ownership
    '95 XM V6 Series 2
    '96 306 XTDT
    Australia
    444
    Mate,
    I have sold all my GS bits, so I can't measure them for you. I am also unable to remember any markings on them - always bought the belts and tensioner assemblies as a kit from Auto France.
    Please be careful of secondhand bearings against a timing belt. If the bearing is even a little worn it may overheat, and then damage the section of the belt it rests against when you stop the motor. On restart the belt breaks, a GS motor does not have clearance between the pistons and valves, and all sorts of internal mischief results.
    Craig is right - pull them off (easy when you are replacing the belts) and look for ID numbers or size them AND replace them whether they look ok or not. Better safe than sorry!
    It is a sure bet they are SKF, but as a special use bearing they may not be marked or available from sources other than Citroen.
    Best of luck,
    fento
    Feb 2006
    Brisbane, QLD, Australia
    515
    Quote Originally Posted by Andy N View Post
    Cheers, Andy
    I got some droplinks (at least 8 i think) but you need to test the condition. I have got at least one set of driveshafts and I would think they got good cv boots. As far as I remember I also got lower arm bushes that i found in the glovebox of the Gs Wagon I bought , they are pretty expensive to buy aren't they so i may have to ask $ for them I made a pair for the 1015 from a standard bushes from Autobarn and they worked fine.
    CX Register
    NSW
    816
    Gees thanks a lot guys for all that help. I am going through CBC bearings and they said that if I could bring a bearing in that they could try and match it. I remember them being a lot more helpful last time I got some belts so I may just have to ring around including SKF, cheers Craig. I see that the Gates belts as a pair are also currently on ebay for around $50-$60 with free postage to buy now. The reason I called CBC was that the service was excellent but only average this time. They can still get the belts in a couple of days though.
    I didn't think about Auto France, Fento cheers for that. wonder if I should call Yongy's sons and see what they have.
    Cheers Garth, I have seen that Citroen Andre have some good parts so will surely give them a call soon.
    And Kimmo, I will have to see what you have because all those parts will hopefully get the GS closer to becoming more driveable.
    -Andy
    Feb 2006
    515
    andy, come around and have a look. i will be in this afternoon.
    CX Register
