traction tools
Thread: traction tools
    NORTH PERTH W.A.
    830
    Icon5 traction tools
    Any idea what these things do
    Attached Thumbnails Attached Thumbnails traction tools-traction-tools-sm-world-17-3-11.jpg
    16,417
    Well I can pick a sparkplug spanner when I see one I'll take a look through the traction manuals tonight, though no doubt Gerry will given a description of use for each of them before then (pitty there is no ball joint, drum puller tools etc... there).
    1000+ Posts gerrypro's Avatar
    Camperdown 3260 Australia
    3,067
    Quote Originally Posted by ARCHRIVAL View Post
    The tool Top centre is for adjusting the ball joint cups on the tie rod ends.
    there are several T handle tool pictured that no doubt are for the bell housing set screws and several other often difficult to reach fasteners. They all look to be homemade, and some of them I have no idea as to what they might be particularly the plates with the holes in them.
    The group of three tools top right in the picture may be for releasing the collets that retain the valve springs
    The only tools that I would even consider useful is the tie rod adjuster and bell housing set screw T spanners.
    Cheers Gerry
    9,771
    The manuals for Tractions have drawings to make a variety of tools. Download a copy and have a look to see what you can regognise from the drawings.
    NORTH PERTH W.A.
    830
    Thanks all I will mark up accordingly and look up the manual if I ever get down to the workshop Note the stepped spanners have differing numbers on them and are different sizes 2220T,2221T,2222T curious
    16,417
    Here's a few from the shop manual
    2200-T --extractor for battery terminal (yes I'm not joking, it pulls the battery terminal from the battery
    1601-T --plug spanner
    2410-T --stud extractor
    1611-T --valve compressor
    1976-T --water pump ball race spindal.
    Oh man, I give up listing them. There's a couple on every single page of the manual. I didn't spot the tool numbers you have listed.
    The plates look like something you would block hydraulic flow on a DS with.... Maybe steering rack tools ???
