DS Auto Electrician
Results 1 to 22 of 22
    Member DStragic's Avatar
    Mar 2011
    69
    Icon5 DS Auto Electrician
    Hey There,
    So I've come to the grim conclusion that my DS has dodgy electrics. Shocked as you may all to hear such a thing, I'm curious to know if anyone can recommend a good auto electrician to put my goddess right? I'm located in Sydney and are willing to travel for the right person. Please don't recommend that I do it myself. Me and electrics are not friends
    Steve
    16,426
    There pretty straight forward. I suggest cleaning/replacing the fuses and earth points will fix the majority of your problems Especially intermittant fuses!
    seeya
    Fellow Frogger! Techbuy's Avatar
    Dec 2010
    West Ryde Australia
    237
    Default electric
    Quote Originally Posted by DStragic View Post
    Hey There,
    Steve
    What exactly is the problem?
    If you are near Silverwater, I might be able to help.
    Give me a call 0416280999
    Colin
    DS
    DS is offline
    Fellow Frogger! DS's Avatar
    641
    NO DS owner will be shocked to hear your car has dodgy electrics!
    My 1969 is the worst as it has/had rubber covered wires which perish and meet other wire and love sparks fly! Your car has plastic covered wires.
    As much of a mess that most DS wiring systems look they are generally reliable. I find lots of cars have wires that once did something but now sit there as a "" what was this wire" type of wire.
    Is there a specific issue your car has?
    Mar 2011
    69
    Glad to hear that the electrical mess under the bonnet is not unusual!
    The car wont start. It doesn't even turn over. Complete silence
    I went through a series of checks:
    1. Fuses - ok
    2. lights - all work - headlights, indicators, dash (oil, battery etc) when key is turned on.
    3. Fuel pump - working. it does the momentary pump
    4. Gear selector (auto) in Park & Neutral. All fine. Wiggled it around to test if slightly off.
    I'm thinking it is either the electronic ignition or alternator. But could be a relay switch???
    As I'm not a mechanic it's all just speculation of course
    8,415
    Are you in the nrma???
    If so, get your moneys worth from them and get one of their road service guys to come out and have a look.
    Jo
    Mar 2011
    69
    Good idea. I think I will
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    There's a wire that hangs off the side of the battery that came loose on my 21 when a new battery was installed, and this produced the same result.
    There are a swag of connections in this area. Give em all a twiddle. It cant hurt.
    What area are you in?
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Fellow Frogger! Stuart Dammery's Avatar
    453
    Bob at Glebe Auto Electrics does some work on my CXs....lovely old bloke. BTW he is in Balmain....go figure
    1980 CX2400
    2000 Xantia Wagon
    Kurrajong
    25
    Sounds like your car is a EFI auto.
    Hanging off the positive battery terminal is the starter solenoid (see attached) photos.
    It has a button underneath.
    Try having the car in neutral or park and with the ignition on, push the button.
    8,415
    It gets better, because when/if need to get it towed to a sparky, they pay the first (?) 10km or so. If the roadside guy fails, as is most likely the case these days, he will give you authority to book in a tow.
    You can fully redeem your yearly subscription fee with those two services alone.
    I have no time for the NRMA anymore and I have found out that their mission statement is a lie. They do not care.
    Unless we are talking about procuring your hard earned dollars, where of course they have a high care factor.
    So fleece them for all you can, with my endorsement.
    Jo
    Mar 2011
    69
    OK, The lovely NRMA man came and identified that there is no signal getting to the starter motor. He got it started (hooray) by attaching a '+'lead from the battery to the starter motor solenoid. This will at least get me going to a workshop. Mcook, you were spot on regarding the engine type (EFI Auto) and the problem area. I've been ferreting around to find the button you described, but cant find it. Will have another look, when the engine cools down a bit.
    Thanks Stuart for the recommendation. I'm in Randwick, so Balmain could be handy.
    Steve
    8,185
    Icon3
    Steve
    Steve, the button is on the underside of the positive battery terminal.
    08 C5 X7 HDi very Noir
    "Dťesse" Roland Barthes, 'Mythologies', 1957
    The Dťesse has all the characteristics of one of those objects fallen from another universe that fed the mania for novelty in the eighteenth century and a similar mania expressed by modern science fiction: the Dťesse is first and foremost the new Nautilus.
    16,426
    Is there a fuse in the soleniod circuit ?? If so *check the fuses*. It sounds like you have an external battery mounted soleniod. If this is the case ensure you have the battery frame well earthed or you will have the exact problem you are desribing. The soleniod earths through the battery frame .... which must also obviously be earthed for the soleniod to work.
    DS
    DS is offline
    641
    My guess is the "which gear am I in" aknowledgment switch on the gearbox has a non connected wire. UFO will no doubt agree on that one!
    CitroŽn Tragic UFO's Avatar
    9,721
    Quote Originally Posted by DS View Post
    I was about to say the same thing because I believe this is the car I fixed one Sunday arvo a few weeks ago.
    Steve, you have identified a way to start it. Get it to the tech day on Sunday and we will look at it again.
    REMEMBER THOUGH, make sure it is in PARK and park brake on when you tap that wire across.
    Sydney South
    601
    This car had a new starter inhibitor switch installed about five years ago. I know this because I was the one who crawled all over the net and finally sourced the part for both it, my car and one other.
    So perhaps it's not the switch, but the wiring?
    Michael
    9,721
    And I think we have a volunteer to diagnose and repair on Sunday! Woohoo!
    Sydney South
    601
    Where is the owl emoticon??? Who who who???
    Michael
    Fellow Frogger! Mort Subite's Avatar
    620
    my 50c each way bet is on this ^
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
    Sydney South
    601
    Here's a pic of the starter inhibitor:
    But I still think a dodgy connection near the +ve side of the battery could be the culprit.
    Even money, I think.
    Michael
    Mar 2011
    69
    Well, I thinks it's settled...I'll just have to come to the Tech Day! Look forward to seeing you there and thanks EVERYONE for all your suggestions, help, advice yaddah, yaddah, yaddah
