DS rear window
Results 1 to 9 of 9
  • 1 Post By GreenBlood
Thread: DS rear window
    1000+ Posts michaelr's Avatar
    1,393
    Default DS rear window
    I have a question about installation of a rear window on a '73 DS. I assume the first job is to glue the lower seal to the metal parcel shelf? Can anyone tell me the best sequence to get the glass in place? How many pairs of hand will it require? I got the front screen in single handed but this back one has me beat!
    Michael
    Member, Citroen Car Club NSW
    8,184
    Icon3
    Quote Originally Posted by michaelr View Post
    Michael, have you read the 'Tony Jackson PDF #D.961-4 Replacement of rear screen'?
    It makes it sound really easy, yes glue the lower seal in place, fit the screen rubber to the screen, they suggest using adhesive tape to hold it in place. Offer the upper screen to the frame, fit glass setting it as far as possible into the upper part of framing, tighten the two retaining backets whilst pushing up on the glass.
    08 C5 X7 HDi very Noir
    Fellow Frogger! Errol_S's Avatar
    Jul 2014
    Devon. UK
    121
    Can someone please advise where I can find a copy of the 'Tony Jackson PDF #D.961-4 Replacement of rear screen'
    Errol
    8,184
    Icon12
    Quote Originally Posted by Errol_S View Post
    Errol
    Errol.
    Download Manuals 814- 1 and 2 here.
    https://www.dropbox.com/sh/tv0b25gpmd5ux8e/e-HYMQrA3e
    You need 814/2 Page 455 of the downloaded file
    Attached Thumbnails Attached Thumbnails DS rear window-ds-rear-glass-removal.jpg   DS rear window-ds-rear-glass-refit.jpg
    Hotrodelectric likes this.
    691
    Hi Michael,
    I know its common practice to glue the seal first, however I've never been able to get it *right* that way, particularly with a new seal.
    In the past I've fitted the rear glass then pushed the seal in place from the inside with some wd40. Once in it does not move.
    If you want to glue it then I would do the above, mark the position of the seal, then remove the glass and glue the seal according to the mark.
    Mark...
    Jul 2014
    Devon. UK
    121
    Duh!! I didn't think of looking at the manual because that is far too logical. Maybe now I am really showing my stupidity but point 3 under removal has me confused - "Using a screwdriver placed between rubber sealing and upper part of window framing, lever the window over the retaining brackets." Are they suggesting prying the top of the window out of the frame, and then simply lifting the glass over the brackets?
    Errol
    8,184
    Icon3
    Errol
    Errol,
    I'm not sure what they are describing there either
    For removal, I completely remove the two lower brackets and lift the screen outward from the bottom (after releasing the left and right demister connections from the inside). No screwdriver!!
    For refitting, fit the rubber to the glass and ease into position then fit clamps and demister conections.
    Ici.
    2,560
    I think steps four (repeated in the text) refer to doing the bottom one first with tape as the seal will be floppy then fit the top seal then stick it in frame then put the brackets on, thats the reverse of how I took mine off, took about 2 minutes to remove it.
    Easy peasy Japoneasy!
    Jul 2014
    Devon. UK
    121
    LOL. Thanks that makes sense. I am glad the removal is simple as once out I have to cut the rust from the C pillars and fabricate new inserts. Oy vey!!
