CX clutch replacement
Results 1 to 15 of 15
  • 1 Post By DoubleChevron
Thread: CX clutch replacement
    Sep 2005
    186
    Default CX clutch replacement
    Can any one tell me what they think is a reasonable price to have a clutch replaced ( Melbourne )
    and
    Is this an engine out job
    and
    Can a home mechanic reasonably do this job themselves
    thanks
    Hawk
    16,414
    Fairly simple... Full engine out. it's not going to be cheap to pay someone to do it (think of the time involved). Remember to source the camshaft seal, rear main, spigot and camshaft carrier bearings while your at it
    Does this help at all ??
    http://www.shanescitshed.com/cx2500/...tch_change.htm
    Sep 2005
    186
    Thanks Shayne,
    That is fantastic information to have available.
    Now we all know why it is an expensive job. A clutch replacement may put many CX's off the road in future - as not worth the cost.
    regards
    Ted
    10,783
    Quote Originally Posted by hawk View Post
    Thanks Shayne,
    regards
    Ted
    Depends what you mean by "not worth the cost". Pollyanna here thinks "good opportunity to replace all those seals within most of the cost" and then the car's good for a long time more.
    The information on this site remains wonderful.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts Greg C's Avatar
    Oct 2003
    1,304
    Based on what I payed to have the auto box replaced, there is about 25 hours work involved to R&R motor, separate gearbox and fit clutch. Then you have to deal with other things that might need to be done while she is out. Like camshaft seal, driveshafts etc. I would say $2k would be a minimum, more if other things need doing.
    Greg
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    10,783
    Quote Originally Posted by Greg C View Post
    Greg
    Sounds near the mark. I've paid similar for a Xantia heater radiator! Worth the money if you keep the car and keep using it.
    We once paid much more than our Renault R8 was worth for straightening her up, but 25 years later, still using the car, it wasn't much really.
    Renault 4CV 1951
    Renault R8 1965
    Feb 2013
    451
    Default CX2200 Clutch - where to buy or can it be re-lined?
    It's come time to do the '76's clutch. Is there an Aussie supplier or is it possible to have the old one re-lined?
    Cheers, Adrian
    16,414
    Quote Originally Posted by Jinandfonic View Post
    Cheers, Adrian
    I'm pretty sure they all use the same clutch. Head down to your local rebuilders and see what they say. They should be able to clamp test the pressure plate for you. A lot of CX parts are readily available on ebay UK these days.
    citroen cx clutch kit | eBay
    don't even dream of doing this job without changing the cam seal
    Others stuff to look at while it's apart.
    --lower engine mounts
    --driveshaft carrier bearing
    --rear main
    --spigot bearing
    That's all I can think of off the top of my head
    Jinandfonic likes this.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    I had a look at that clutch kit, put my car details in and, it apparently doesn't fit my car. i have done an extensive search and cannot find one anywhere. looking for a new clutch kit for a 1976 CX 2200...
    Oct 2003
    1,304
    How about these at CX Basis
    1. Clutch kit for CX 2000
    CX-BASIS :: eShop
    2. Clutch disc 2200/2400
    CX-BASIS :: eShop
    Seems to confirm Double Chevrons thought that 2200 and 2400 clutches are the same.
    Mine
    CX Prestige
    Toyota Prius
    In the family
    Xantia SX
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    When I was a Kid and needed a new clutch for the Hillman, I would just take it into one of the places that re-lined drum brake shoes and they would re-line the plate, put in new springs and skim the faceplate - anyone know if these places still exist?
    Melbourne, Victoria.
    1,389
    Hi Warren,
    modern clutch parts are throw away. I think the re-builders have gone the way of the " cords oil control rings" engineers.
    I'd be very surprised if anything is reconditioned these days. When given the option people usually put in new parts.
    There are plenty of brake and clutch replacement suppliers these days. The European importers would have new parts.
    However it's usually much cheaper to source the parts from England.
    Cheers... George 1/8th.
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Yeah, probably went the way of the guys who could "stitch" cast iron, producing a repair that was heat and pressure proof - my grandfather new how to do it.
    Feb 2013
    451
    Quote Originally Posted by WRB View Post
    Best price & here in Aust. Search eBay: EXEDY OEM replacement Clutch Kit CTK-7552 suits CITROEN 228mm
    WRB
    WRB is offline
    Sep 2012
    Burwood Vic
    558
    Great, thanks for this
