Removing interior door trim on DS23
Results 1 to 15 of 15
    Member DStragic's Avatar
    Mar 2011
    69
    Default Removing interior door trim on DS23
    Hey There,
    I'm wanting to remove all the interior door panels to take a look inside the doors and perhaps do a rust treatment. Or will I just be looking at the rust???
    Anyway, to the real question....any special tricks to removing them, and getting them back on?
    Thanks,
    DST
    PS - my first post!!
    Citroën Tragic UFO's Avatar
    9,721
    You could join the CCC of NSW and come to our tech day in a couple of weeks time in Sydney. Lots of tricks to be learned from the knowledgable.
    http://www.citroencarclub.org.au/
    Jun 2003
    Lauderdale, Tasmania
    2,887
    Leave them in place and remove the outer panels, it is much more of a challenge.
    16,426
    Gee's, your all such helpful people
    push the door trim back around the window winder handle.... and you should see a pin you can push out allowing the handle to come off. Then just put your fingers behind around the edges and ease all the clips out of the door. Don't be surprised if your tear some out of the back of the door trim if it's been wet at some point. It's been a few years since I've removed one, but I"m pretty sure it's that straight forward.
    8,185
    Icon3
    Quote Originally Posted by DStragic View Post
    Hey There,
    Thanks,
    DST
    ...hmm, not a very good welcome for a new member
    DoubleChevron pretty well covered it, only thing I'd add is that on the Pallas you have two sort of triangular clips front and back on each panel, these need to be carefully prised open they are if memory serves me right, alluminium and after 30+ years can break.
    Welcome to Aussiefrogs, more comedy than Hey hey...
    08 C5 X7 HDi very Noir
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    Actually, I think they're on the DS models, as my non Pallas DS23 has these little clips.
    Incidentally, I've seen they are available as a repro part if you do break them.
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    Jun 2003
    2,887
    UFO's answer is the right one. This is a trivial task that can end up in a tiresome mess. Don't be tempted to pull on the panel to unseat the clips. Use the panel beater' tool like a Splade that lifts the panel around each clip. Once off, you will probably need some new clips, new plastic thimbles in the door and some skill in repairing crumbling cardboard. If checking for rust you should remove the window sills and check their clips as well. Now you need help from your friends, if things have not changed in Aus recently. The clips etc are not off the shelf items and so you need a mate who has a few left over from the ones he imported when he did a restoration.
    8,185
    Icon10
    Quote Originally Posted by gerry freed View Post
    Thanks Gerry, all good stuff and more appropriate advice to a 'new' member, I'm sure he'll get used to your 'quirky' humour
    16,426
    You can buy these tools. I haven't been too concerned in the past as the door panels are generally trash after 30years either way (from people pulling on them to get them off). You will also scratch the paint using tools if your not careful.
    If your going to use a tool, get the plastic ones
    http://cgi.ebay.com/ebaymotors/INSTA...motiveQ5fTools
    I should buy a set of my own someday
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,228
    Hi DST
    welcome to the forum.. I've found it very useful.. members always ready with tips or advice. I Pulled the rear panel off one of my D Special doors.. I had to unscrew the arm rest as well as remove the window winder.. but it was very easy and it pulled off without a fight.. just worked my way around one clip at a time.
    Do you have a pic of your car you can share?
    Matthew
    Mar 2011
    69
    Thank you all for those that have provided me with some very good tips. To answer a few questions/comments:
    1. Thanks UFO (Craig), I am a member of CCC NSW. In fact I was the 'newbie' who had to introduce myself in the last meeting in front of a big crowd. I think I said it was a "baptism by fire". Much like the Aussie Frogs Forum )
    2. Thanks GreenBlood as 'Grand Master'. Your paternal comments are appreciated.
    3.Hi Matthew, no photos so far but will post some soon. I've followed your questions and the following answers have provided me with valuable info.
    DST (aka Steve)
    Jun 2003
    2,887
    How can you accuse a Citroënist of being quirky?
    8,185
    Icon12
    Sorry Gerry, I don't know what came over me, perhaps a L J K Setright moment?
    Fellow Frogger! Amopallas's Avatar
    140
    Is LJK Setright still living?. I enjoyed very much reading his unique opinions of cars,having seen some photos of him,he always looked thin and emaciated. Joe
    1975 Citroen DS 23 Pallas
    9,721
    DST (aka Steve)
    Ah! So you bought Paul Smith's car and you joined CCC - well done. I was the smart @rse in the back corner, but I have to do double time as Deb is at the front of the room.
    Well you know about the tech day and people like Darren and Martin and many other knowledgeable people will be there that day. Much to learn from the sages. A great day out.
