CX wagon question
Results 1 to 15 of 15
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    750
    Default CX wagon question
    Can anyone give me the measurements of the rear window of a CX wagon please?
    Width at top and bottom (if different) as well as the height please?
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    San Diego, California, USA
    3,534
    The door glass or the rear quarter?
    16,426
    Do you have a door glass there and your trying to figure out if it's prestige or wagon ??
    i can measure the top part of the window, but I'm not dismantling the car to get an accurate measurement of the lower window width
    750
    I'm just after some idea of the size of the glass area in the tailgate. It doesn't have to be to the thousandth of an inch (or mms) I'm happy with the size from rubber to rubber.
    Thanks fellas
    Ross
    Current Cars
    1991 Mazda E2200
    16,426
    The tailgate window ?? Gee's I thought you meant the back door windows Tailgate is easy. Hang on, I"ll go measure.
    16,426
    about:
    850 across the top of the glass
    1200 across the bottom
    540 height.
    750
    about:
    540 height.
    Thanks for that Shane
    Regards
    Ross
    Current Cars
    1991 Mazda E2200
    10,815
    Quote Originally Posted by rmac View Post
    Regards
    Ross
    If you put a vertical panel behind the rear seat, you could grow anything at all in that greenhouse. And no-one would think of checking it out........
    I forget just how big the wagons are!
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1,475
    When you go to reverse, there's quite a distance between you and the rear window after you look past two rows of seats.
    1972 SM
    1989 BX 16 Valve
    750
    Default more measurements required please
    My reason for seeking the tailgate glass size was to get some idea of the cost of a perforated vinyl graphic. It would reduce light and heat penetration (or so we are led to believe) Have found out that the vinyl sheet width is 1500mm.
    I'm now wondering what the rear glass panels measurements are? The ones between the rear door windows and the tailgate. I'd need to know the length at top and bottom as well as the height at the front and at the rear please?
    Thanks to anyone who can help.
    Current Cars
    1991 Mazda E2200
    16,426
    Get a high quality "lighter" coloured tint put in there. It made a staggering difference to my CX sedan They block 60% of the heat transfer through the glass (it makes such a difference you travel windows up if the sun it out, not matter how hot it is).
    1,475
    Converting the CX to a 'shaggin' wagon', Ross?
    Where will you put the mirrorball?
    1972 SM
    1989 BX 16 Valve
    750
    Quote Originally Posted by donat View Post
    At my age any balls would be appreciated!
    As for a 'shaggin' wagon I wouldn't lend my prized new possession to anyone so there is not likely to be any of that going on!
    Current Cars
    1991 Mazda E2200
    Fellow Frogger! John P's Avatar
    Somerville, Victoria
    153
    Length is 860mm at the top, 990mm at the bottom. Height is a constant 380mm. There could easily be a variation of over 5mm from car to car depending on how snugly into the body the trim strips are stuck on. Hope this helps.
    2006 C5 2.0 HDI estate - daily driver
    1981 2CV - The Amelie project is complete.
    1930 C6F torpedo - My Great Folly! Project under way.
    750
    Quote Originally Posted by John P View Post
    Thanks very much for that. Now to make a few decisions.
    Current Cars
    1991 Mazda E2200
