DS side mirrors
Results 1 to 25 of 26
Thread: DS side mirrors
    mnm
    mnm is offline
    Croak croak... mnm's Avatar
    Dec 2010
    3,228
    Default DS side mirrors
    Hi hi hi
    my D Special has one side mirror on the driver's side. It is clamped to the door edge and has a round mirror. I notice other cars it is bolted to the door.. Is my mirror a Citroen piece? There's no hole in the door to mount one of the other type mirrors.
    Matthew
    600
    yours looks like an aftermarket mirror
    Citroën Tragic UFO's Avatar
    9,721
    I have seen similar clamp on mirrors on Tractions.
    Australia
    444
    I have at least one still lying around - definitely 'fit all' non original. Were handy for clamping to the Traction door edges, although not good for the paintwork.
    fento
    9,721
    Quote Originally Posted by fento View Post
    fento
    Funny you should say that, because you know which Traction I saw them on first. Although Ron fitted some nice stainless (I think) plates for them to mount to.
    BVH Roger Wilkinson's Avatar
    Warrnambool
    2,346
    That mirror is a period accessory. I mounted a Nasco one that looks much the same on my 1959 DS19. I know it is from the right period as I removed it from our FE Holden ute when it died.
    Roger
    mnm
    mnm is offline
    Dec 2010
    3,228
    Roger
    That being the case then, why wouldn't the car have the bolt on type? Were they an option? And how do I go about fitting them? Drill?
    Matthew
    9,721
    Look on the inside of the door. Is there any evidence of a hole having been there and covered up.
    mnm
    mnm is offline
    Dec 2010
    3,228
    No, both doors are smooth. I'd have to see another car to see were they go exactly. Here's a pic of what my car will look like in another life So they're just below the top crease in the door?
    Matthew
    Attached Thumbnails Attached Thumbnails DS side mirrors-burgundy-ds21conf-front-open.jpg
    1,475
    Matthew,
    My dad's 1970 DSpécial which he had in the early '80s had the same mirrors. Not sure if that answers your question, but it shows your car isn't the only one of that vintage with said mirrors.
    1972 SM
    1989 BX 16 Valve
    mnm
    mnm is offline
    Dec 2010
    3,228
    It does thank you. I'd prefer the other type though.. the clamp on one is pretty wobbly..even after tightening.. and it rubs on the edge of the bonnet.
    So if anyone has any experience in fitting the bolt-ons let me know.
    Matthew
    Fellow Frogger! Mort Subite's Avatar
    620
    Quote Originally Posted by mnm View Post
    Hi hi hi
    Matthew
    Interesting that there are no mirror holes in the doors.
    Just to add to the collective data, is your DSp an Australian delivery / compliance plated car, with power steering, turning headlights and rear demister? If its a private import then that would explain the variation..
    My understanding was that with the rationalisation of the range for '70, Aust got DSpecial or DS21Pallas (replaced with DS23Pallas) with DS21wagons/DS23wagons...
    Might it be a 69 model year ID?
    CITROEN CAR CLUB of NSW - MEMBER. www.citroencarclub.org.au. . .www.facebook.com/CCCNSW
    08FD DSPECIAL "Dear Prudence wont you come out to play?"
    00FF7512 DS23SAFARI "Pull up to my bumper Baby, in your long black limousine."
    C2MY06 C2VTR "Go speed racer, Go"
    YDO005 MORRIS MINI DELUXE "The Mini Deluxe floats on fluid too"
    Fellow Frogger! Le Parisian's Avatar
    Guildford West
    359
    Default DS Mirror
    I have some after market mirrors fitted to my 69 they wont be there for much longer
    691
    Hi Matthew,
    It's an australian Wibroc mirror - designed to fit either drivers and/or passengers side.
    My 21 has one fitted and it's an "original" Australian D accessory. As I've seen quite a few D's with them fitted so I'm pretty sure some dealers must have fitted them from new. They used them on Holdens, Fords, Valiants etc. as well.
    There is also a version with a trapezoidal mirror head which is the one I have.
    I much prefer these to the french ones as no holes have to be drilled and they are probably "correct" in Oz. Using an appropriate rubber gasket solves the paint damage issue.
    Pretty easy to find on ebay from time to time.
    EDIT - forgot to say - mine does not rub on the bonnet - so I suspect it's an adjustment issue.
    Mark....
    mnm
    mnm is offline
    Dec 2010
    3,228
    Quote Originally Posted by Mort Subite View Post
    It might be an import.. it has the Lucas tails lights as well. Compliance plate says ID 19 Series B I think..
    Fellow Frogger! CorneSoutAfrica's Avatar
    South Africa
    589
    Matthew
    So you settled on the rouge de grenade?
    Awesome!!
    Corne
    1968 ID21 break
    1971 DS21 IE BVH Rouge de grenade (Madamoiselle Rouge)
    1974 DS Pallas Sable metalisse My first restoration (Edith) Now BVH
    1973 DS pallas Metallic red. "Rusty"
    1947 Traction Avant
    Modern
    2006 C4 VTS 180 Coupe
    What would life be if we had no courage to attempt anything?
    - Vincent van Gogh
    mnm
    mnm is offline
    Dec 2010
    3,228
    Yes I think that's the go.. lovely deep red.. my favourite colour. Will keep the white roof. Rouge interior..mmmmmmmmmmmmmmmm!
    Attached Thumbnails Attached Thumbnails DS side mirrors-rouge%2520de%2520grenade%25203.jpg
    Fellow Frogger! Ronhic's Avatar
    450
    Deep red/burgandy with a either the same colour or black roof would look stunning, just unbareable to drive in summer...damn it!
    South Africa
    589
    My semi automatic will be rouge de grenade with a black vinyl roof, winter car
    Corne
    1968 ID21 break
    1947 Traction Avant
    Modern
    - Vincent van Gogh
    8,185
    Icon12
    Hi hi hi
    Matthew
    ooooh look, new old stock, more likely fitted to a Traction but...
    http://global.ebay.com/CITROEN_PEUGE...567251631/item
    08 C5 X7 HDi very Noir
    mnm
    mnm is offline
    Dec 2010
    3,228
    Am I right in noticing that the stems on some rear view mirrors are longer than others.. like this pic. Looks very elegant.
    Matthew
    Attached Thumbnails Attached Thumbnails DS side mirrors-3921139626_8c9abf51ab_b.jpg
    8,185
    Icon12
    Matthew
    The correct fitment left and right mirrors have different length stems, one mirror will have slightly convex (or is that concave) glass.
    Feb 2002
    Coolum Beach
    1,919
    Matthew
    French car. How can you tell?
    DS Un jour, DS toujours !
    DS23 IE Pallas Automatique
    C5 X7 163 Exclusive
    C3 II 2010
    9,721
    Matthew
    Yes. On a D the passenger side mirror has the longer arm to I suppose give a better field of view. In the photo you linked it shows a LHD car hence the right arm being the long one.
    I bought the mirror cool kits to replace the plastic rubbish surrounds on my car and the kits all come with convex mirrors. They are not overly exaggerated and give me a better view of idiots who dare to get within 1 metre of UFO.
    (BTW - You look into a (con)cave and you exit a convex)
    8,185
    Icon10
    The barstados
    I'm thinking of fitting spikes like the bug in 'The cars that ate Paris'
