2CV Handbrake pad removal
    Feb 2011
    230
    Default 2CV Handbrake pad removal
    Hi
    I have an 87 2CV6 Special , can the handbrake pads be replaced without taking the calipers off ,
    Im hoping they can , and also where would I get this LHM hydraulic oil for the brakes ,, it has disk brakes on the front
    Feb 2011
    Perth Australia
    20
    A very big yes though it is better to remove the front guards for better access.
    I remove the hand brake cables and then the levers then with a magnet it is easy to remove the old button pads.
    The adjustments can be time consuming but after you look at how they work it is a breeze.
    Most good auto parts places have LHM and the Citroen Club in your state will be able to help.
    Feb 2011
    230
    Default Thanks Bob
    Will give it a go , happy Frogging
    Thanks for the quick reply
    I kind of understand how the handbrake section works , typical Citroen or French,,,,, strange but works OK
    Feb 2011
    230
    Default Hi again
    Am running the 2Cv around a lot today ,, my other car Honda Jazz has failed a gearbox bearing at 20,000 Kms , I saw a nice yellow Megane with F1 stickers on and it looked good
    Renault make a nice F1 motor but aussies dont seem to take to the French brand
    JBN
    JBN is offline
    1000+ Posts JBN's Avatar
    8,235
    Quote Originally Posted by Renburg View Post
    Did you end up replacing the handbrake pads, or do you carry a brick around with you?
    John
    Feb 2011
    230
    Default Jbn
    I carry 2 pieces of 2x4 in the boot and use them , the wife thinks the handbrake is OK
    Im not sure,,,,as I drove with it on and may have deteriorated it but how can you tell???
    Have not ordered parts
