Advice for buying an early V6 petrol C5
Results 1 to 3 of 3
    grb
    grb is offline
    Feb 2011
    Sydney Australia
    2
    Default Advice for buying an early V6 petrol C5
    I have a Xantia V6, but am tempted by an early C5 V6. Are there any clues on what to be wary of? I know that this is probably old ground, but as the cars get older more information comes to hand. Do they have any auto gearbox issues?
    Gordon
    9,777
    Condition and service history is very important now as there are quite a few rough examples out there that you simply do not want to own. It's the same engine and gearbox as in your Xantia, so same chance of failure there. Make sure it works properly and doesn't shunt going up a hill in top gear as this indicates torque converter problems. Look at usual used car faults and make sure everything works, but also check for hydraulic leaks from the suspension and power steering. The switch on the power steering pipes visible directly in front of the engine can leak and can be replaced separately to the pipe set. It's important that the harmonic balancer isn't turning due to failure of the rubber. Engine mounts are prone to sag and also snap the centre securing bolt, so that is worth looking at. Lack of performance issues are often caused by blocked exhaust/catalysts.
    grb
    grb is offline
    Feb 2011
    Sydney Australia
    2
    Default Thanks
    Thanks David,
    I appreciate the advice.
    Gordon
