CX questions
Thread: CX questions
    Fellow Frogger! rmac's Avatar
    Denmark, Western Aust.
    754
    Default CX questions
    Three questions about the CX
    1: Have been quoted $120 to have each front retractor seat belt webbing replaced. Are replacements (whole unit) available, or an aftermarket that will fit available? At what price!
    2: exterior mirror on driver's door is electrically operated. Can/does the mirror head unit swivel? At the moment it needs to be repositioned so that I can see cars closer to my tail.
    3: How difficult is it to remove the steel trims on the tops of the doors (below the window glass) and do they need special clips to refit? Car has a few rust 'bubbles' along these strips that need attention.
    Current Cars
    Australia's 2016 C5 2.0HDi Last
    2011 C5 2.0HDi Comfort
    1973 Citroen D Super 5,
    1981 Citroen CX 2400 Pallas C-matic,
    1981 Citroen CX 2400ie Super Familiale C-matic - Raid Arctique 2014
    1991 Mazda E2200
    1924 Citroen 'la petit citron'
    Feb 2006
    Brisbane, QLD, Australia
    515
    In my experience the steel rim is easy to remove but tricky to get off without damaging it. It is held in with plastic clips that break when it is removed.
    New clips found here
    http://cx-basis.de/eshop/product_inf...oducts_id=1630
    CX Register
    NORTH PERTH W.A.
    853
    1. try klipan seatbelts but price aint going to be much cheaper
    2 mirror I assume glass just moves in the casing and the casing moves under shock or for folding back when parked or negotiating tight spots
    3. window trims secured by plastic clip slotted into metal pin or pop riveted on early cars I think
    754
    Thanks for the swift replies. The mirror head doesn't seem to move. Either it is rusted solid or was fixed in position. Suppose I could try some spray, soak and let penetrate before applying a bit of 'gentle' force.
    Will have to get some clips then for the strips. Thanks.
    Current Cars
    1991 Mazda E2200
