BX 16V suspension
    Fellow Frogger! Andreas's Avatar
    Sep 2000
    1,200
    BX 16V suspension
    I'm not to familiar with Cit's so be gentle with me
    All pug 405's with 4x4 were fitted with the BX rear suspension but retained the original 405 front setup.
    Now from memory i think the front on a BX is also hydraulic?
    Now in case you're wondering where this is heading, i'm looking into converting my 405.
    I have found the parts in the UK from a wrecked 405 mi16x4 but if I can get it locally from a BX it would be easier and I would also like to convert the front.
    But my main concern is whether or not the front will fit and whether or not the BX fuel tank is the same as that of a 4x4 405 (different to a FWD 405).
    And lastly were any of the BX's 4x4?
    Andreas
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    Andreas,
    There are two BX 4x4s. The 'normal' with a transverse engine, and the 'hot' one with a lengthened nose and a north south engine.
    There are as far as I know no 4x4s of any type in Australia, but some of the former in NZ.
    Paul
    Paul Smith
    DS23 EFI BW Auto
    G Special 1220
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    16,370
    Hi Andreas,
    Pauls right BX4x4's were never sold out here. However last time my old man was in the UK one of his friends was GIVEN a BXGTI 4wd. Dad had a look at the car, perfect leather interior, unmarked exterior, and was told it's mechanicly good (my guess is it needed repiping ie: the salty road eat out the rear suspension lines).
    Now you know how much BX's are worth in the UK, if you want a 'Pug' with 4x4 and front&rear hyrdaulic suspension, I'd suggest importing a BX. Changing a 'Pug' over to full hydraulic suspension woud be an enormous task (that's the understatement of the century). I'm sure the BX and 'Pug' will use the identical rear suspension, so maybe if you have a 4x4 pug it'll bolt directly in. However if you have a standard 2wd pug I think you'll have a very hard time. Nothing is impossible if you want it enough, but my guess is it'd be cheaper to import the car (and easier) in the long run.
    Here's what you'll need off the top of my head. Hydraulic pump, lines, pressure regulator, height corrector, rear suspension assembly, spheres, transfer case (and gearbox output), tailshaft. The biggest problem is all this will need to be mounted on what's probably a very different structure (you can be sure the 4x4's have different mounting points all over the place).
    hope I haven't put you off. It sounds like one hell of a project. Keep us posted.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Andreas,
    I would suggest you have a word with "Father Goose" AKA Bruce Elsegood on this one.
    Bruce is a TAFE teacher in mechanics, an acknowledged expert on Cit hydraulics, a glutton for punishment on problems such as this & an all round good guy who will help out if it is humanely possible.
    You can contact him at
    [email protected]
    and either tell him that I told you to contact him or use Craig Keller's name - he'll probably murder him
    Alan S
    Sep 2000
    1,200
    thanks for your help guys, you havent put me off yet
    i know that the 405 FWD and 4x4 chassis is the same as a friend in Europe has converted the 4x4 conversion using 405 parts.
    but i wanted to take it a step further and fit hydraulic suspension to the front aswell.
    I can get the all of the necessary parts from a 405 in the UK but wanted to knwo if the suspension parts atleast can be found here as i dont necessarily want to convert it to 4x4.
    are the 4x4 and FWD BX suspension systems the same?
    Andreas
    8,923
    Andreas,
    There is a club of Citroen 4 X 4 owners in the UK. They seem to be pretty full on with these things and seem to be contactable.
    http://www.geocities.com/bx4x4regist...hnical.htm#top
    http://www.geocities.com/bx4x4register/
    Hope this helps answer your questions.
    Alan S
    [This message has been edited by Alan S (edited 17 August 2001).]
