Here's one for the Technical boffins.
Results 1 to 3 of 3
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    I have had an accident with a return line from my accumulator.
    Here's one to try your little brains out for you; LHM is a mineral based fluid as is motor oil & petrol so how long will rubber based hose suitable for petroleum/diesel or motor oil last if I use it as return line for LHM. This is of course assuming that I don't clout it with an oil filter removal strap like I did the last one.
    Please give me the news I want to hear because I can't remember where else I've used it.
    Alan S
    Feb 2001
    Romsey, Victoria, Australia
    4,822
    Alan,
    I have seen people use fuel line in an emergency, it will work, it goes soft after a few weeks but it will get you out of trouble.
    David.
    David Cavanagh
    03 9338 8191 or 03 93354008
    34 KING St
    AIRPORT WEST
    VIC 3042
    [email protected]
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    Tool/fastener/Engineering stores/suppliers usually sell hydraulic oil hose which isn't very expensive and it is made to take alot of heat and pressure so it's pretty durable.
    I use large diameter hydraulic oil hose as a cheap and longer lasting alternative to genuine heater hoses on my 504.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
