Cambelt- 1.7 Diesel
Results 1 to 3 of 3
    UK
    2
    Cambelt- 1.7 Diesel
    I read (Parkers Car Check - a UK thing?) that cambelt failure in the XU series engine is always terminal. Presumably this applies to the XUD?
    Anyone had cambelt failure & survived?
    Are there any easy checks without taking the head off?
    Jono
    16,370
    Hi There,
    I assume you mean a BX diesel, unfortunatly these cars were never sold in Australia.... However point your browser to:
    http://members4.boardhost.com/citroen_bx/
    The BX Citroen board, it's mostly UK based but they have much experiance with diesel engine BX's and cam belt breakages.
    I have heard of them breaking at low engine speads and surviving, but there is only one way to find out.....
    good luck,
    Shane Leviston
    May 2001
    Norway
    1
    [QUOTE]Originally posted by Jono:
    [snip]
    Well, it's not possible to have a cambelt breakdown and surviuve due to the engines geometry. Pistons are bound to crash with the valves (or at least one of them....) causing damage. I've experienced a cambelt breakdown at low RPM with my 17 TRD (Norwegian designation - not to be mixed with the english "turd")Camshaft broke, but beyond that - no damage so far (the car has run approx. 10k km after the incident)
    Yes, a compression test would give you a lot of info.
    Regards
    Geir-K. (NO)
    -89 BX 17 TRD
    -89 BX 14 RE
    Regards
    Geir-K. (NO)
    -89 BX 17 TRD
    -89 BX 14 RE
