Leaking hydraulics
    Mar 2006
    Swansea
    1
    Default Leaking hydraulics
    Vehice Xantia 1.9 TD 1996, has decided to leak its vulcan's blood into the drivers footwell. Has any one encountered this before, if so what was the fix? Would save me a bit of time ripping the thing to bits!
    Regards
    Fellow Frogger! chris's Avatar
    Jan 2005
    Sydney/Marsfield
    376
    Are you sure it's LHM rather than coolant? Xantia heater cores die after a certain age. There was a long thread on this ages ago, as I recall. The other possibility mentioned at the time was that the LHM tank had been overfilled and was overflowing when the car settled and running inside somehow.
    GS 1220 break. Beige cars go faster
    Fellow Frogger! Jack Z's Avatar
    Aug 2003
    Gosford, NSW
    302
    Odds on it's coolant...
    By pass the heater as a temporary fix and that will confirm it...
    Then it's dash out time
    BX TZI Hatch
    BX TRI Hatch
    GS C-Matic
    16,754
    If it's the heater matrix dump some BARS stop leaks into the coolant reseviour. Apparanty the new valeo heater cores come with the instructions to use bars leaks ........... (so much for bloody good quality products..... Even when new there admitting "this is going to leak" ).
