Xantia gearbox?
Thread: Xantia gearbox?
    Fellow Frogger! PSvensson's Avatar
    Silverwater
    164
    Default Xantia gearbox?
    Last year I had to replace my gearbox and the replacement gearbox has these nubers on top
    20CM00 C
    4611616
    Is this a Xantia gearbox? or a peugeot gearbox.
    Does these numbers make any sense?
    1970 ID20 SUPER
    1971 DS21 IE non PALLAS,5 Spd
    1973 DS20 SUPER Singapore model but now an Aust resident(Rebuilding)
    Late 1994 Xantia VSX 5speed (for sale)
    1966 R10 round eye (sombody want to buy?)
    NSW
    4,918
    Icon7
    Was it manual or automatic?
    How much was it if you dont mind us asking?
    Silverwater
    164
    Its manual and $1400 for 2nd hand robbery!
    The centre diff part hypoid I think they call it shot out the caseing (inside bell houseing and outside )
    1970 ID20 SUPER
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,076
    Hi,
    Where abouts on the gearbox are these numbers written. My sone has the BE3 gearbox out of his BX 16 valve at present and I could compare numbers if I could find them. It has BE3 cast in casing just to the right (as you face the front of the car) of the top gear change lever.
    I think BE3 is a type description and the 20CM00 C will be a model number which describes the exact sorts of parts and gear ratios that the box contains. I think the bottom number will be the serial number.
    I know AX gearboxes had this sort of labelling and I have seen a label on the BE3 in either my BX TZI or Xantia when doing the clutch but I can't remember which and can't find where I wrote it down.
    Ken W
