Creaky C4
Results 1 to 7 of 7
Thread: Creaky C4
    Feb 2006
    Perth
    16
    Default Creaky C4
    My C4 has the panoramic glass roof, which is, I must say, worth every cent. The only problem I have with it is if I park the car in the sun for about twenty minutes on a day warmer than 30 degrees the roof creaks as I drive over road imperfections. I believe it is down to the glass and adjacent metal expanding at different rates. Has anyone else had this problem? In such a quiet car it is very annoying.
    Interestingly, park the car longer than about an hour and it doesn't creak. I suspect that the metal and the glass have "warmed through" and done all the expanding they are going to do.
    Dec 2004
    169
    C'mon it just would'nt be right if a Citroen did'nt have at least one annoying problem!
    1000+ Posts Uga Boga's Avatar
    May 2004
    1,057
    It's called character!
    407 3.0L Exclusive (2007)
    Expert 2.0L (2009)
    Laguna 2.0L dCi (2007)
    Feb 2006
    Perth
    16
    Forgive me. I'm new to Gallic cars. My last four cars were Japanese
    Fellow Frogger! Paul Smith's Avatar
    Camperdown, NSW, Australia
    624
    I would be keeping an eye on it - one of the road test cars (SMH?) cracked its glass roof for no apparent reason.
    Paul
    Paul Smith
    1974 DS23 EFI BW Auto
    1974 G Special 1220
    http://www.simplicitas.com.au
    Tadpole C3PO's Avatar
    Feb 2006
    Gold Coast
    9
    We have a C3 Panoramique. Sunroof front section and fixed rear glass panel. It has been wuite warm here in Qld. but have not noticed any creaking from either the moving or fixed panels.
    I assume that the large fixed glass panel is expanding at a different rate to its surrounding materials. Perhaps the glass section is slightly out of alignment and rubbing as it expands. Worth making sure it is recorded in your cars records at the dealer just in case something untoward happens.
    Kind regards,
    C3PO
    2005 Citroen C3 Exclusive Panoramique Hatchback.
    2004 Chrysler Crossfire Coupe.
    Tadpole Simmo's Avatar
    Feb 2006
    1
    I've had a VTS with panoramic roof for 6 months now and I haven't noticed this. I do get a door rattle intermittently from the passenger side which is a bit annoying. Otherwise no other creaks.
