Xsara Vts Window died
    Fellow Frogger! mattg's Avatar
    Feb 2005
    Port Macquarie NSW
    191
    Default Xsara Vts Window died
    Hi All
    Well it has happend. The drivers door on my VTS has given way and has died. Has anyone bought a replacement from andyspares? if so was it a "citroen" replacement or aftermarket brand if get what I'm saying.
    I believe it is the cable that breaks, I'll be taking the trim off to chuck a bit of wood in there to keep the window up and will understand better then but I was goin to take it to an engineer mate to see if he can replace the cable. If he can hopfully we might be able to work out a way to recondition these regulators and save everybody alot of mony and stop them repeatedly breaking. I can't believe the dealer wants $600 for the part.
    Matt
    MattG
    2002 Xsara VTS
    Local Tyrant gibgib's Avatar
    Mar 2000
    Sunshine Coast, Queensland
    3,528
    Seems like a common fault
    Yet another broken window mechanism!
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    This is just a thought, but has anyone tried taking one of these to one of these guys who make up clutch and accelerator cables by any chance?
    I remember Peter Routs from Newcastle had a speedo cable made up for his BX16V by a guy in Melbourne and it was tailor made for the car and a lot less than dealer price.
    By this stage you'd have to reckon someone's found a shortcut.
    Alan S
    Fellow Frogger! Boyracer's Avatar
    Sydney South
    601
    Are there any pix of what the guts of these things look like?
    I'm curious and have already been warned to expect a similar scenario with the Pug. It's the same setup from what I hear.
    Did I hear someone say 'built in obsolescence'?
    Michael
    ____________________________
    Citroen Car Club of NSW - Member
    1974 Citroen DS23 non Pallas BW Auto/Carby with Air-conditioning [AC640 Delta Blue]
    1972 Citroen DS21 5SPD EFI Pallas [AC088 Blanc Meije]
    2012 Citroen C5 Exclusive 3.0L Auto Diesel [Noir Perla Nera]
    8,923
    I have suspicions that it's more a case of built in factory propaganda like used to be the case with spheres (can't be recharged) cambelts (can't be changed unless you have a Seems tester) and so on.
    Having worked in my trade, it's amazing what can be reconditioned; all it takes is someone to discover there's a quid in it and we're away.
    Alan S
    Feb 2005
    Port Macquarie NSW
    191
    I am about to strip the door down and I'll take some shots along the way.
    Regards
    Matt
    MattG
    2002 Xsara VTS
