Xsara stalling
Thread: Xsara stalling
    Fellow Frogger! robo's Avatar
    188
    Default Xsara stalling
    My VTS Xsara sometimes stalls when i have the aircon on, usually at idle when stoped at lights but did it today when changing gears..
    Has anyone else had this prob ?
    Cheers Mark..
    Fellow Frogger! mattg's Avatar
    Feb 2005
    Port Macquarie NSW
    191
    Hi Robo
    Might be your Idle speed motor.
    Matt
    MattG
    2002 Xsara VTS
    Nov 2002
    Yarrabilba, Queensland
    2,760
    I haven't looked into the efi system on the Xsara but your problem sounds like the idle control actuator as mentioned.
    If the car is still in warranty jsut take it back and get it replaced.
    This was a common problem with Bosch LH2.2(and similar systems) jetronic and is a symptom of a failing idle control motor. If you can remove the control motor and clean it with carb/throttle body cleaner it may work better for a while.
    Previous
    2001 Rx-4 Privilege
    R17TL, 1973
    R20TS x 3
    R18 GTS wagon x 2
    R10
    188
    Thanks guys, have got just two months left on the warranty.
    Cheers Mark..
